£8,000
1999 Peugeot 306 Rallye
  • 2000cc
  • Red
  • 153 miles
  • No tax
  • No MOT
  • Some service history
  • Cambelt changed: Jan 2026
Modifications: None
Contact: 07584472691
displaying posts 1 to 2 of 2
Author Subject: 1999 Peugeot 306 Rallye
Peugeot 306 Rallye for sale!
This has undergone an overhaul I will put up a project thead detailing what i've done to the car in my ownership
But for now we'll just bullet point!
. Mileage 153,134
. Taxed 1st September 2026
. V plate Rallye but comes with Private plate R90LYE
. Starts first turn of the key
. Little to no rust
. Heater Matrix replaced just before I bought it by previous owner 2023
. New cambelt kit put on January 2026
. New Valeo Water pump January 2026
. Just Cambelt swaped out with Gates one (after servicing hydrolic lifters) May 2026
. New Valeo Clutch january 2026
. Mint Interior
. Mot till 19th August but will get it a full MOT
. Fresh Oil and filter done 8th July 2026
. Air filter changed March 2026
. X5 Cyclones powdercoated Silver
. X5 michelin pilot sport 3 195 50 15 tires
. New Discs and pads last year
. New drop links
. New Ball joints
. Fuel Filter replaced July 2026
. New fuel filler neck Elbow Pipe July 2026
. Fuel relay switch
. New Bosch Lambda sensor
. New Throttle Position Sensor Lucas
. New Crank position Sensor
. New Vehicle Speed Sensor Febi
. New NGK Ignition Coils
. New Radiator Fan Switch
. New Exhaust Rubber Hangers
. New Gear linkages
. NEW Genuine Cat to Exhaust manifold bolt kit
. New Bosch Areo Blades
. Hydrolic lifters seperated soaked in petrol put back in all genuine original
. Injectors service and flow checked
. Front Calipers rebuild and painted 2K Renault Liquid Yellow
. Original airbox
. Still has battery box Lid
Modified / Upgraded parts
. My own personally fettled gearknob fully refurbished
. Genuine Citroen Xsara mist washer jest (absolute god send over oem)
. JVC KD-402 Headunit (red lighting to match the car)(do still have tape dec needs TLC)
. 32bg USB for the Stereo
. Alpine Type E front speakers (I do still have the originals)
. Taylor made 306 Rallye floor mats front, rear and boot
. Scorpion Back box (somone has welded to standard mid section)
. Citroen Xsara VTS rear beam added by previous owner
. Engine bay repainted
.engine repainted black enamel
.inlet manifold and cam covers painted Audi Le-Mans Silver
Most of the replacement decals were provided by Vehicle Decals UK (aka Rikki)
Roof lining vanity mirrors etc and painted black
Bad Points
The paint work needs attantion
Laquer peels left right and center as well as colour fading
Typical of red cars painted with cellulose paint!
. There is a rust spot on the wing by the indicator
But its solid so a flat back to metal a bit of filler if needed and she'll be good as new!
Theres a few dings just above passenger door handle
I had a paintless dent removal man out to it but because theres a plate above the handle he couldnt get it all out
Will need skiming and painting
. The rev counter gives a little flutter when key turned to position on
And off (im investigating it)
. Door switch not working properly previous owner disconected earth wire so needs sorting otherwise interior lights dont come on
and alarm doesnt warn you your lights are still turned on when the door opens
There may be more bits I've forgotten about and will update acording to when
The alzheimer's lets up and the painful memorys of what I did return
The price is reflected on as the car sits at the moment
If paint and Body work is done the price will go up significantly
I can vinyl cut a set of Rallye decals taken from an original set I obtained
A few years ago for a Black Rallye if the next owner would like to get it fully repainted
Here are some pictures to wet your appetites!
Thank you for looking i'll be at The Peugeot Festival 2026 if your interested come and take a closer
Look!
Please don't hesitate to get in touch!
Posted 24th Aug 2026 at 09:39
Quick update
I did an emissions check on the car prior to taking it gor an MOT
The cat failed misserby ie next to nothing left of the internals
I got another great condition genuine CAT which has been fitted
MOT Tuesday
Posted 24th Aug 2026 at 09:42
