Author Subject: Fuel pump priming / Ignition off
Joka-cro
Hi guys,after complet rebuild of entire car,starting it m evrything works fine but after ignition off, every few minutes ( 4-5 minutes) i hear relay to turn on and pump to prime for 2-3 secends.....
Changed fuel relay,changed ignition lock and all is still the same....
Any ideas ?
Besides that (maybe are thos 2 problems somehow connected ) with ignition on and headlight switch off the headlights are turned ON.... Dunno chenged the switch but still the same...
Like the car is geting positive signal from battery somehow ?
Posted 1st May 2026 at 17:44
jimmyhackers
this is normal, it is to keep the fuel lines primed and the fuel swirl pot full.
check your headlight relay, it might be stuck on.
Posted 4th May 2026 at 18:23
Joka-cro
You think that is normal when i turn the vehicle off and locl it that pump turns on ? Iknow that on newer peugeots when youbopen door pump primes for 2 3secends....
About lights,I disconected all relays and light switch and they are still on.... As I am informed 306 is not using any relay for headlights
Posted 9th May 2026 at 11:43
pug_306
Tends to do that with a unlocked ECU
1992 205 GTi6
205 Turbo 340bhp
Posted 11th May 2026 at 11:34
