Author Subject: brake vacum booster pump removal question?
jimmyhackers
i have the deletion plate from spoox :s
install all seems pretty straight forward.....except.
the t peice non return valve....that will become redundant with fitting.
do i need to replace it with a non t-peice one way valve inbetween the remaining brake servo vac line and the inlet manifold line??
or can it essentially be a straight/open bit of tube between the two?
Posted 3rd Jan 2026 at 06:33
why?
Posted 9th Jan 2026 at 20:10
jimmyhackers
i dont know why i give him my money.... at least it wasnt one of his bespoke silicon intake replacers (£182)
Thumbs down
i found a suitable new t-peice on ebay for 13 quid LOL
on a less "duck spoox" note.
1. old one was leaking oil.
2. looked messy.
3. was noisey
4. the t-peice one way valve half failed. it was just slowly pumping air (and condensatable water) into my rocker case.
5. new t-peice valve is expensive/rare af. ??
6. ive never needed a booster pump in my xsi, which is essentially the same vehicle.
i image a lot of french "abrutis" saying the brakes are s**t and "thats why i crashed" the earlier 306 hot hatches...
and peugeots responce was this pump?
only a guess?
Posted 18th Feb 2026 at 16:46
