Author Subject: engine decarbonization, snake oil?
jimmyhackers
i know carbon deposits are a thing.....
but has anyone seen how much of a thing they can end up being in a gti6 engine with an endoscope camera or engine dissasembly?
i keep seeing hydrogen decarbonization service posters in garages and tyre shops......
so i de mothballed and plugged in my hydrogen generator and went for a home brew approach. Big grin
HHO gas into the air intake till the engine and oil was warmed up, then the HHO gas plus 250ml of distilled water misted into the engine intake with the revs raised to about 2500 over 10ish minutes.
there was a puddle of black sooty water in the exhaust and on the floor below/behind my exhuast afterwards. engine feels a little smoother, less lumpy, quieter even. but thats alll butt dyno.
again, are carbon deposits a thing for the gti6 engine?
ive orderd a cheapy phone camera endoscope but its kinda redundant asto if my method does/did anything.
i also did similar to the above a week after with some inlet valve cleaner...spray through a running engine.
my only thoughts are/were for the valvle cleaner were faulty oil breather coats intake inside with oil,dust, grime n grot gets trapped in this oil....reducing intake diamaters.
thoughts? pics?
Posted 30th May 2025 at 18:07
jimmyhackers
got me endoscope camera, first use, thought it was a load of rubbish or its leds were low power junk, black screen.
pulled it out and the thing was covered in sludgy oil LOL
i think i need to remove and clean my intake manifold and intake valves. Whistle
ive ordered some thermally insulative intake manifold and throttle body gaskets for a test.
ive also premptively removed/catch canned the oil beather pipe that goes to the throttle body and plugged the throttle body hole.
ive also ordered an inlet resonator delete plug....will have to have a search on here if to see if its worth it.
hopefully it all gets here before next weekend. might post a before and after pic if i remember.
Posted 7th Jun 2025 at 17:51
i can't see how any of it would work, you're either risking hydrolocking the engine or just messing up the air /fuel mixture, I can't figure if it would make it lean or rich.
certainly not the best thing for the cylinder bores, you should see a block from an engine that's had a leaking headgasket ignored for a while, and then there's the lambda that typically gets toasted.
Posted 7th Jun 2025 at 22:05
jimmyhackers
i think the "theory" is high pressure super heated steam forms in the combustion chamber and cleans the carbon deposits.
although this steam will only touch the combustion chamber and the exhaust valves, not the inlet side of things.
the hydrogen cleaning services...just use HHO, i guess its introduced as a compresible gas, so much less chance of hydrolocking and its a fuel and oxidiser in one.
a lot of the anocdotal evidence does say from a headgasket failure you can tell which cylinders had coolant in it as its got way less carbon on it.
i think if a service technician turned up with a spray bottle full of water instead of a big expensive machine, youd be less inclined to part with the 50-100 quid.
as for the inlet cleaning, a can of egr valve cleaner while the engines been running seems to be useless aswell.
theres no real substitute for removal and manual cleaning of valves it seems, cant wait to do my exhaust Razz
Posted 8th Jun 2025 at 01:54
jimmyhackers
i did the gaskets and cleaned it all in about 3 hours this afternoon.
the old gaskets were rather past their best.
went for a therma-tec thermally insulative gasket inlet manifold and throttle body set, 29.99 for them from the ebay. they seem good quality. little bit thicker than standard but went on ok with the oem bolts.
was rather oily inside the inlet manifold. port walls leading to the inlet valves were oily but the inlet valves and their surrounding area/walls were reasonably clean.
the port closest to the throttle body was the dirtiest. the further away the less oily.
it was rather interesting to see the oil patterns, where it was and wasnt deposited.
it looked like the intake runners were oilier on the sides of the tubes closest to the throttle body.
it was the same for the intake valves....the valve in each port closest to the throttle body was slightly oilier.
i guess this would suggest, greater airflow/cleaning effect against the far side (from throttle body) of each runner and intake port?.
either way, so far so good, might of even solved my weird cold start 2000rpm hesitation issue.
Posted 19th Jun 2025 at 18:23
