Author Subject: window popping woes :(
jimmyhackers
when i got this gti6 the driver window mechanism was somewhat "exploded". i replaced it with a new unit.
however the window mecanism nipple thing pops out of the circular rubber bung every now n then (leaving the bung and clip in the glass).
needless to say, i can refit it in under 5 mins now. but id rather figure out why.
the glass is in its rail/clip to the rear and its in the guide bar at the front... bung is new and metal clip seems ok.
any chance something stupid like the 2nd hand unit is from a 5 door 306?
it did work backwards with the window switch when i first fitted the new unit (up=down and vice versa)...so ive swapped the pins in the plug to fix.
window will pop out sometimes when i shut the door and the windows half open, or if the MOT mechanic leans on itLOL .
Posted 14th Apr 2025 at 20:30
might be the wrong type of clip for that mechanism, some used the plastic square from memory.
Posted 19th Apr 2025 at 10:40
jimmyhackers
window glass fell out again when window was all the way down and i shut the door. Sad
ive ended up putting a 1.5mmm thick plastic washer on the window rails lower bolt/stud to space the mechanism at its lower end towards the window glass......So far so good.
Posted 9th May 2025 at 17:19
