Author Subject: clutch pedal ocassional "click"
jimmyhackers
every now and then when depressing the clutch pedal i feel a click/clunk. not sure what it is. the recalled helper/adjuster thingy isnt there....so its not that.
ive had the plastic bit on the pedal end of the cable snap on me before in another 306 and every time this happens i get paniced its happened again. but everything is fine it would seem.
this never happened in my other gtis and the xsi and wondered if anyone knows what going on?
thanks
jim
Posted 15th Feb 2025 at 12:35
Joep
I have some issues with the clutch pedal in my XSi6. It rattles like crazy (sounds like a relay on steroids clicking) when driving above 80km/h.
Sound disappears when slightly pressing the pedal. So, I thought it was the adjuster.
However, checked everything, and all seems tight enough and all works well...
So, maybe for your 306 it is only a sounds and everything else is okay.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 17th Feb 2025 at 09:57
jimmyhackers
did some footwell gymnastics on sunday.....findings were:
1. the clutch cable was rubbing slightly on the rubber/foam trim, scalpel to remove the offending rubber. bit of silicone spray down the hole, result is pedal is smoother, no light creak, but im doubting this was the cause of the random click.
2. accelerator pedal is pressing against the same trim, its worn through the black rubber and exposed the orange foam behind :S not related to click but still another random worry.
3. GODDAM PEICE OF S^%T HEATER MATRIX IS LEAKING, F%^KS SAKE!!
excuse my french Smile im guessing the occasional click is just my clutch cable adjuster adjusting...weird ive never noticed it before as this is my 5th 306/3rd gti6.
Posted 17th Feb 2025 at 13:49
ale624
You checked the bushing on the top of the pedal itself looks ok?
if i remember correctly it's a plastic bush. If it's got a crack in it, it could be opening up and clicking when you're pressing the pedal
Posted 11th May 2025 at 13:23
