Author Subject: engine dying on the move :(
jimmyhackers
urgh...
two days ago my engine cut out twice on the way home from work. yesturday it did it once.
today it had difficulty starting.....and cut out half way to work, refusing to start again. (its curently sat at the side of an A road)
its had new spark plugs, coil packs, map sensor, ICV, o2/lambda, TPS, fuel pump relay, fuel pump.
fuel pumps priming and engines cranking....so im thinking its an igniton issue.
maybe crank sensor? any other ideas?
Posted 23rd Aug 2024 at 07:15
jimmyhackers
towed the car home.... new/old cam sensor did f-all.
took the spark plugs out....every one is firing nice and strong.....but they were all dry. (no fuel)
i have fuel upto the rail (at pressure) so i figure the injectors are not firing/opening/being sent a signal. (should it be 12v?)
turning it over i might get one cough in every 20 or so cranks.
which makes me think intermittant break in the wiring that feeds the injectors. is there a common loom break point?
any ideas on what would stop the injectors firing?
Posted 23rd Aug 2024 at 09:58
jimmyhackers
well.....every injector is getting 12v so its maybe not the loom.
i have swapped the fuel pressure regulator for a spare i had, it wasnt that and there is defo fuel in the rail.
but it still doesnt start Sad
what are the odds every injector decided to block itself at the same time? :S
Posted 23rd Aug 2024 at 11:54
jimmyhackers
urgh..... went through the hassle of taking out injectors.....
they spray in an even misty pattern.
i have spark and i have fuel.....
im at a loss now.....
only thing i noticed was....the fuel pump primes...but its not running when i crank the car.
and almost immediately after i stop cranking it primes for a short while again.
is this normal?
Posted 23rd Aug 2024 at 16:59
jimmyhackers
well, a new crank position sensor didnt help either Sad
neither did cleaning the front earth points on the passengr side chassi leg. (does crank slightly faster now though)
Posted 23rd Aug 2024 at 21:43
jimmyhackers
SUCCESS!!
the brand effing new fuel pump i fitted all of 3 weeks ago failed, it was still working but giving low pressure.
i have fitted the old unit and the cars fine again.
probably running better now ive cleaned all the earth points Razz
i will be getting a refund for the pump.
Posted 24th Aug 2024 at 16:48
