Author Subject: clarion cd changer (says connect) HELP!
jimmyhackers
been tinkering with my calrion radio.... i dont know the code.
i cant enter any codes. (locked) just 4 dashes and the number buttons do nothing.
the cd changer in boot ejected its case and all that jazz, seemd to work fine.
i took the head unit out and unplugged everything so i could read barcode/serial and hopefully ebay person can give me the proper code.
plugged everything back in.
now the cd changer is dead, no ejection etc.
found on here if you hold the wave button while turning it on, you unlock the unit for a short while..... radio works fine, all buttons too.
however if i try and press the cd changer button the radio says "connect"
i have unplugged and replugged the cd changer cable at both ends several times to no avail and it still doesnt eject its case and the headunit still says "connect"
any ideas?
thanks in advance
jim
Posted 3rd May 2024 at 15:00
jimmyhackers
urgh.....
disconnected my battery today to do an ecu reset.
radio doesn't power up anymore. on button does nothing. fuse in back is ok. screen is dark.
right after the ebay guy sends me my code for it. :S
and sods law, now the cd changer in the boots works again, it ejects and cycles through.
this cars fighting me Sad
Posted 4th May 2024 at 20:28
jimmyhackers
not sure how or why. but driving out my supermarket today...
the 4 dashes appeared on my radio screen
held the wave button for 10ish seconds.....says enter code.
entered code.....everythings working SWEEEEET.
perhaps the cars saying thanks for filling the gearbox with the correct amount of oil.
either way im happy.
Posted 6th May 2024 at 13:15
jimmyhackers
urgh, for the past few weeks its been fine.
a few days ago the volume buttons started playing up, not working or working delayed.
then it was fine for the past few days after.
today the cd changer has gone back to "connect" when i press the cd button on the head unit.
and the eject button on the cd player no longer works. Sad
Posted 31st May 2024 at 20:59
jimmyhackers
got the car back from getting its clutch done. so the battery has been unplugged, put in the radio code and the cd changers working/recognised again.
ill see if a battery disconnect fixes the problem if it happens again. but once again, happy
Posted 15th Jun 2024 at 22:48
jimmyhackers
thing decided it wanted to turn on by itself and not turn off.
took the unit out and apart. found one of the two connectors for the fascia had come off. resoldered the 8 legs. did the 6 on the other one that was still attached to be sure.
thing works like a charm now.
Posted 31st Aug 2024 at 01:12
jimmyhackers
had a weird issue the other day, cd changer was fine when i parked up at work, said connect when i left..
no power, wouldnt eject
the head unit needed to be disconnected and reconnected to its power to fix it, i pulled the fuse for ease.
i have a feeling my silly little odessy battery is dying (after 6 months from new). so when it gets low it trips some nonsense with the cd changer. i figure the batteries suckyness is amplified by the cold.
Posted 16th Nov 2024 at 15:57
jimmyhackers
Things been fine ever since i swapped to a normal battery.
then today, i just had to mess Sad
got a new 2nd hand cd changer as it has the flap cover (mine doesnt), test plugged it in, thing didnt eject or work, mechanism seemed stuck. took the flap cover off. sprayed the mechanism and jiggled it, eventually got it to eject and cycle its case (4 free cds Big grin). but the damned thing wouldnt play, it would just load the cd say its playing but stay on 00:00.
no biggie i thought, just fit the cover to my original unit. now the bloody thing says connect when i press the cd button on the head unit, it reverts to radio, but if i press the cd button again it connects the cd changer and everything works fine until i restart my car.
:S
Posted 27th Mar 2025 at 21:15
jimmyhackers
battery disconnect fixed my issue.....just weird it happened.
Posted 29th Mar 2025 at 13:35
jimmyhackers
had another differnt issue with radio yesturday.... would turn on but buttons were mostly unresponsive.
tried a battery reset and after it would say input code, with none of the buttons working.
took the facia off the front again..... found the main power switch button was constantly closed despite button position......iso alch cleaning an its fixed.
Posted 14th Jun 2025 at 14:29
jimmyhackers
goddam radio.....every time i remove the 6 cd changer boot cassette it messes up the cd part. just says connect.....usually requires a radio reset to fix.
but this dam time when entering the code it spammed the first number button i pressed 4 times....locked the damned thing ffs, now i cant enter the unlock code...
i know i have to leave it powered for x amount of time before i can reenter a code.....
at this rate i might just swap the aftermarket radio from my dormant xsi. ill sadly lose the 6 cd changer, the ability to play tapes.....but gain mp3 cds and bluetooth connectivity.....
Posted 17th Jul 2025 at 16:37
