Author Subject: that big metal bush in the gear linkage?
jimmyhackers
anyone got a link to where i can get one?
the big cylindrical sleeve one that wears out first Smile
failing that, theres so much play i think i could make a shim out of a coke can and slide it in there. anyone done simliar?
TIA
jim
Posted 23rd Dec 2023 at 14:25
S8-Tom
It's known as a Glacier bearing. Hovis16 has got the dimensions of the one you need (might be in his project thread somewhere).
Posted 23rd Dec 2023 at 15:16
jimmyhackers
couldnt find it on th ethread but found another site saying this is the one, ID 32mm, OD 36mm, length 40mm
https://www.bearingboys.co.uk/BU-Type-Bearings/MB3240BU-Split-Bearing-Bush-14905-p
correct?
Posted 23rd Dec 2023 at 21:29
S8-Tom
jimmyhackers wrote:
correct?
I think so. You could try roughly measuring your old one. I definitely bought mine from bearingboys Thumbs up
Posted 24th Dec 2023 at 10:15
heliosphan
This could hardly be more topical for me; I was under the car disconnecting the gear linkage last night.
Just to be clear, is this the cylinder thing at the front end of the selector rod which houses a big ball on the subframe-section of the linkage?
There's also a smaller brass(?) sleeve at the bottom of the gear stick, directly above the catalyst at the rear end of the selector rod. This didn't seem to have much play for me.
Posted 24th Dec 2023 at 11:05
S8-Tom
Yep, cylinder thing at the front of the selector rod. The ball of the linkage that pivots on the subframe runs on the glacier bearing
These one's?
Posted 24th Dec 2023 at 20:23
