displaying posts 1 to 2 of 2
Author Subject: Lost off power in high revs
RichardB
I have this issue,
In high revs my Xsara VTS is running less power random.
Rollertest curve is like a the mountans…
What can be the problem.
Reading code P 0556
Posted 22nd Jun 2023 at 19:09
jimmyhackers
internet says code is related to brake booster servo....
so.....there could be a vacum leak somewhere, messing with your brake booster and also map sensor readings and inturn your ecu.
redneck solution to find a vac leak is spray brake cleaner (flamible stuff) around your engine bay with the engine on and see if revs increase when you spray it in one area.
Posted 22nd Nov 2023 at 16:36
