Author Subject: Power - No Start
sixxer
Fault-finding time:
Car has power, new battery, fuel pump primes.... The Starter motor is not seized and will bump start. Going through FAQ http://www.306gti6.com/forum/showthread.php?id=168902
Also below the inlet manifold is an unattached cable with a blue connector next to an attached cable/blue connector...
Just want to narrow the problem down before taking the car into local garage...new starter motor
Posted 28th Apr 2023 at 15:19
S8-Tom
Could be:
Crank position sensor.
Multi-plugs on front of chassis rail on passenger side.
Fuel & spark relay on back of battery box.
Inertia switch (red one behind the battery box)
You've said you can hear the pump prime, be worth pulling a hose from the fuel rail to check you've got fuel arriving there (if no fuel then fuel filter blocked?)
Have you got spark?
Posted 28th Apr 2023 at 15:41
as it will bump start it will not be;
Have you got spark?
check if you are getting 12v to the solenoid wire.
Posted 28th Apr 2023 at 15:46
