Can a Quaife diff be removed from a gearbox and run like it did before the diff was fitted? Or does something need replacing to let it run without the diff?
| Author | Subject: Quaife diff removal |
99rallye
Regular Location: Hitchin Registered: 26 Aug 2009 Posts: 348 Status: Offline |
Hi all, looking for some advice.Can a Quaife diff be removed from a gearbox and run like it did before the diff was fitted? Or does something need replacing to let it run without the diff? |
you need a standard Peugeot BE large planet gear diff.not sure why anyone would take a quaife out, unless it was to put a plate LSD in... ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
99rallye
Thanks for the advice.I've got a donor car with a diff in it and I was figuring out if I could just remove the Quaife before I got my Rallye box out. What it sounds like I need to do is get both boxes out and do them at the same time. Quaife into Rallye and planet gear diff into donor car. |
Easier to just swap the box, saves buying diff bolts________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
99rallye
Ok, that makes sense. I don't think the donor gears are as good as mine, having driven it. If I want to keep my gears I presume I'll have to remove the diff? |
99rallye
What's the name of the bolt set that I'd need if I do need to replace the bolts? |
Diff/Crownwheel bolts.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
