It needs a new cooling fan.
I think it is OEM part 1253J2
What is the best replacement for the entire fan and shroud?
Nissens?
NRF?
Any others?
| Author | Subject: Cooling fan OEM brands? |
iplay
Seasoned Pro Location: Number Wang Registered: 18 May 2006 Posts: 3,272 Status: Offline |
I have a Gti6 P3 with aircon.It needs a new cooling fan. I think it is OEM part 1253J2 What is the best replacement for the entire fan and shroud? Nissens? NRF? Any others? |
ecia or gate was the brand marked on them from memory, ecia was a psa subsidiary, motor is different between them.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Autodoc have the nrf complete item at £118 today for the ecia variant________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
iplay
once again thank you so much for you help.do you have a link for your £118 one? |
https://www.autodoc.co.uk/nrf/2389404 ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
iplay
I realise now that the ECiA motors are generally higher 310w vs Gate 200w.I think the 310w versions are for hot countries? My reg brings up the 200w Gate version. Would a 310w rated front fan run the engine too cool in the UK. or is it better to have a higher rated fan? |
fans wont run it too cool, that's the thermostats job, it'll just cool faster.interesting you found it listed as 200w, the parts data doesnt list a power for the ECIA variant, nor is there any specific data to notify which type is fitted where. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
iplay
Some where in the forum at 'euro gti6' owner discussed the difference between 300w and 200w fans. Apparently the 300w version was for hot countries. And Auto doc lists the NRF for my reg with 200w Gate. |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
FYI, I've just fitted the NRF fan and shroud from autodoc and as expected it isn't a direct replacement. When you swap the wiring over to the new one it just about reaches but the connectors on the new fans don't quite fit like original. I haven't fired it up yet but hopefully it all worksEdit: seems to be working fine! |
woody.
Edit again: fans seem to have lasted 2 years. The motors are spinning but the fans are not! So I think where the plastic fan blade fits on the motor shaft and should be keyed to it, this must have rounded so need remove the plastic fan and have a look.Bit annoying as the OE ones lasted 23 years compared to 2 years for the NRF ones |
