Author Subject: Super charger tensioner set up without pas
dcc
Hi, has anyone got some info on a lynx charger kit non PAS tensioner set up?
Thanks
205 GTI
Xsara HDI
Posted 26th Jan 2023 at 14:18
The PAS pump gets moved to the air conditioning pump position so the original place can be used to mount the supercharger.
Posted 26th Jan 2023 at 14:28
S8-Tom
I've looked at relocating the PAS pump recently. I'm using parts from a non-A/C 2L 8v engine as the brackets put the PAS pump at the bottom and they're also much lighter.
Alternatively, there's a couple of kits available. The Lynx version is available from Pug1Off or a slightly cheaper version from Spoox
Posted 27th Jan 2023 at 09:15
You guys missed the point, NO PAS....
Charger and alternator are fitted.
Posted 27th Jan 2023 at 13:33
dcc
Suppose that I can just run the Pas as a pulley mei, but I would have thought somebody had run a charger without Pas set up
205 GTI
Xsara HDI
Posted 27th Jan 2023 at 16:28
I remember someone on here ran the Lynx supercharger with air-con so removed the PAs pump and fitted an electric pump.
Posted 29th Jan 2023 at 23:52
