Author Subject: Injectors CC and equivalents
vts_188
Hey guys thank you for having me
I'm a filthy imposter in my Xsara VTS
I had some issues with injectors a while back and shoved a set of injectors that are meant for a slightly bigger engined Volvo and although it solved most of the issues the car just struggles to idle and smells horribly of unburnt fuel. It's about time I got proper replacements since I've been doing quite a bit of other work on the car.
However OEM stuff is kinda pricy (~£127 PER INJECTOR) so was wondering what CC the originals are if anyone knows since I can't find my old ones to get them tested and fixed up, or if you know of any good equivalent injectors. I know the resistance is around 12.5 so anything in that range should work but just really need something with as similar as possible.
Thank you!
p.s. the car is stock and has no engine modifications
(for now muahah)
Posted 26th Nov 2022 at 16:57
Weber IW-204 i believe is the stock injector. I think they're 265cc.
Might be worth doing an oil change in the near future incase you've ran it too rich for a long time and contaminated your oil with petrol.
Posted 26th Nov 2022 at 22:29
Phase2 xsara has different injectors.
Posted 27th Nov 2022 at 11:13
vts_188
I know those were the PH1 injectors just like on the 306 but the Phase2 xsara has different injectors with the more modern slim shape we see now Sad and I know they're slightly higher CC since people upgrade to them
And yes planning on fully servicing it after the whole ordeal 🫡
Posted 28th Nov 2022 at 15:00
Seems they are valeo/sagem 348007 injectors, oem number 1984 F0
Posted 28th Nov 2022 at 17:02
Ah, my bad Doh
Posted 29th Nov 2022 at 18:19
vts_188
Yeah know the numbers would just love to know what CC they are Sad can't seem to find the specs anywhere
Posted 30th Nov 2022 at 19:30
