| Author | Subject: radiator hoses for heater matrix |
jwilshere6
Newbie Location: wellington Registered: 27 Sep 2019 Posts: 3 Status: Offline |
Hi, i've got a coolant leak that looks to be around the heater matrix hoses, does anybody know the part number for these? thanks![]() |
alcon
Senior User Location: Glasgow Registered: 19 Jan 2005 Posts: 941 Status: Offline |
6464LH________________________________________ 1999 GTi-6 (china blue)1999 Rallye (black) |
Not been available in a long time and specific to a git6/wallye/vts, there are 2 o-rings where its located into the heater mstrix, that appears to be cracked though________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
S8-Tom
Regular Location: Chichester Registered: 02 Feb 2018 Posts: 356 Status: Offline |
The plastic part is the same on all 306's (+ Xsara, early Berlingo/Partner) but the rubber hoses are specific to the GTI-6/VTS as Welshpug! says.I got the plastic part from a donor car, cut the rubber in a suitable place and joined to the GTI-6 hoses with a 20mm pipe joiner and some clips. It's all hidden behind the heatshield so never seen. Alternatively, remove all of the rubber from the donor plastic bit to expose a barbed end and join to the silicone hoses available from Baker BM ________________________________________ 1343Z4 coolant hose o-rings for sale198131 injector o-rings for sale |
jwilshere6
S8-Tom wrote: The plastic part is the same on all 306's (+ Xsara, early Berlingo/Partner) but the rubber hoses are specific to the GTI-6/VTS as Welshpug! says. I got the plastic part from a donor car, cut the rubber in a suitable place and joined to the GTI-6 hoses with a 20mm pipe joiner and some clips. It's all hidden behind the heatshield so never seen. Alternatively, remove all of the rubber from the donor plastic bit to expose a barbed end and join to the silicone hoses available from Baker BM i was going to try this also, just wasn't sure if the plastic part is the same on all cars as i went to a wrecker to check a convertible which looks like this: ![]() the plastic bit has an extra little hose for the bleeder valve which i'm not too sure about. |
pug_306
Seasoned Pro Location: Great Hockham Registered: 28 May 2013 Posts: 1,597 Status: Offline |
jwilshere6 wrote: S8-Tom wrote: The plastic part is the same on all 306's (+ Xsara, early Berlingo/Partner) but the rubber hoses are specific to the GTI-6/VTS as Welshpug! says. I got the plastic part from a donor car, cut the rubber in a suitable place and joined to the GTI-6 hoses with a 20mm pipe joiner and some clips. It's all hidden behind the heatshield so never seen. Alternatively, remove all of the rubber from the donor plastic bit to expose a barbed end and join to the silicone hoses available from Baker BM i was going to try this also, just wasn't sure if the plastic part is the same on all cars as i went to a wrecker to check a convertible which looks like this: ![]() the plastic bit has an extra little hose for the bleeder valve which i'm not too sure about. Yes that's fine, that's just a difference in bleed screws for earlier and later models ________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
