displaying posts 1 to 2 of 2
Author Subject: Rear screen washer
Gti666
So I’m having issues with the rear screen washer. I have pressure at the pump but the hose to the back is blocked. Does it have a one way valve somewhere that might be stuck shut?
It’s also blocked where the water goes through the wiper pivot. Is there a way to fix this?
Thanks.
Posted 13th Jul 2022 at 11:36
ad
Disconnect the tube at both ends and blow it through with an air line, it's usually just crud build up inside the tube. Worst case replace the tube. They don't have a one way valve as far as I know. Or de wiper it...
Posted 15th Jul 2022 at 23:12
