Author Subject: Replacement Fuel Relay
justsamo
Evening folks,
I need to replace the fuel relay on the 6 as a next step in the list to get it to start.
Tried the crank, cam, battery, earths and immobiliser fuses as per the masses of threads with people having similar issues to no avail. (Cranks and cranks but will not fire, pump primes upon switching on ignition but that’s it - will continually prime if I bridge the connection)
I can see two different ones on eBay with part numbers:
19207 & 19203 - seem to differ on price and availability but wondered if either will work?
Cheers,
Sam
Posted 10th Feb 2022 at 23:07
pug_306
240107 is the one you need buddy :-)
1992 205 GTi6
205 Turbo 340bhp
Posted 12th Feb 2022 at 10:35
justsamo
Thanks mate - seems that part number serves a load of cars much newer!
https://www.ebay.co.uk/itm/Peugeot-15-Pin-Fuel-Control-Management-Relay-Module-240107-/163964996383?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0 This one would be ok?
Posted 12th Feb 2022 at 13:17
pug_306
I can do you a good used one for £10 inc Del buddy
But you can by a non branded one on ebay new for around £15, just type 240107 and loads will come up :-)
Regards
1992 205 GTi6
205 Turbo 340bhp
Posted 14th Feb 2022 at 16:28
russbez
learn something new every day
My Rallye project thread
Posted 18th Feb 2022 at 08:31
justsamo
Thanks for the offer mate. Managed to get one from a local breakers but still no luck with getting it started!! Aside from trawling the whole forum does anyone have any other ideas please??
Posted 24th Feb 2022 at 16:33
Joep
I recently learned that the fuel relays are very engine dependent. There seem to be about 5 slightly different RFS engines, all with their own fuel relay… one that does not match the engine will not work.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 25th Feb 2022 at 06:50
Joep
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
A rfelay simply switches on and off so how can any be different?
Posted 25th Feb 2022 at 08:03
Joep
Yes. But the fuel relay is not a simple relay... the circuit inside can be quite different. My mechanic (who is called the RFS whisperer for a reason) explained it to me last year. There was one RFS engine not running. He checked the fuel relay and noticed the diagram was different to another one. Changed it: et voila. The engine turned over an ran just fine. We checked if the old one was broken on another engine, but it was still working well.
On the outside one can see the diagram. If this matches your old one, it should be fine.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 25th Feb 2022 at 11:12
russbez
You think if part codes are same it would be same double relay setup
Pins are same
They look identical
Just bought one to that came off a 1.6p 307, same part code
Cannot compare my old one as the casing is damaged since like 2005... wiring diagram isnt there anymore. Fingers crossed it works
Posted 25th Feb 2022 at 12:29
Joep
19207L is also a part number for a 306 fuel relay... as long as the diagram on both is the same, these should work I guess..
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 25th Feb 2022 at 14:14
russbez
havent tried turning my car over since i slotted the newer relay in my car, will try soon
edit - got a Fuel Relay from 1.6 petrol from a 307 to work seems good, maybe i was lucky
(fuel relay 240107)
Posted 28th Feb 2022 at 10:39
justsamo
Glad it got you running - no joy on my part so the investigation continues. If I sort it, definitely going to try and write a big FAQ that consolidates every possible check and cause that we all can use for future!!
Posted 28th Feb 2022 at 10:37
justsamo
So still no luck with mine despite a different relay - I’ve just tried a new battery in desperation and whilst it turns over like lightning it’s not firing - I’ve got no spark and the plugs are dry so I don’t think the fuel is getting past the injectors. Help please!!
Posted 20th Mar 2022 at 18:45
Is the crank position sensor definitely working?
Do you know anyone with an unlocked ecu you could borrow to test that?
Posted 20th Mar 2022 at 20:19
justsamo
Bought a brand new crank sensor and tried a spare also so can’t be that!!
I wish I did know someone with one - trouble is I don’t know anyone down my way with a 306 let alone a gti6..
Tried looking up getting an unlocked ecu but that rich guy doesn’t seem to be about anymore?
Posted 20th Mar 2022 at 20:46
Ben_W
Formerly gpm
Cully, who knows these inside out, is in Cullompton, near Exeter
Posted 20th Mar 2022 at 21:47
justsamo
Ah, I’ve just looked him up but not posted since October..
I’m certainly leaning towards immobilise/ecu now but I’ve no idea about getting hold
of one. Really can’t see it being anything else at this point as I’ve tried everything else.
Posted 20th Mar 2022 at 23:39
Ben_W
Formerly gpm
Get on the Facebook page bud. He's plenty active on there, although last I heard he was selling up but had a barrel load of spares. Might have an ECU
Goes by the name of Paul Vincent
Posted 22nd Mar 2022 at 13:23
justsamo
Bit of a dinosaur with Facebook.. is there a specific gti6 page on there?
I have found him though I think!! Cheers
Posted 22nd Mar 2022 at 20:16
justsamo
So I’ve sorted my issue - turns out the transponder chip in my key had gone “faulty” and lost the immobiliser code and wasn’t recodable. A local auto lock smith was able to put a new chip in the current key and it fired right up! Thought I owed it to you all to advise it was sorted. Smile
Posted 5th Apr 2022 at 22:56
