Author Subject: XU10J4R Idle problem after swapping engine.
FrancoSss
Hi there.
I'm having a problem with my RPM.
Everything is OK while driving, acceleration is good and no problems. except when I want to stop, the RPM goes down quickly to 500-450 and then goes up to 900 then back to good 800-850. some times it goes off especially when the air conditioner is working!
In general the RPM goes down to 500 and fluctuates back and forth to become stable after seconds.
1- I changed the stepper 3 times!, nothing happened.
2- checked the ECU and no faults detected, numbers were OK. I even changed the ecu several times with no changes!
3- Throttle intake is clean.
4- after warming up the engine, if I disconnect stepper cable the engine becomes stable and fine.
5- after disconnecting stepper the ecu reads no faults on (PP2000) and this was tested on three different ecu's.
Technician claimed that sensors are good.
In general RPM does not go up high numbers, it only goes down 500 and back to 1100 max then it starts to stabilize at 800.
NOTE: car was 405 1.6L engine, I swapped engine with Citroen Xantia 2.0L XU10J4R one, I faced this problem after swapping. After discussing this matter with others, it seemed a common problem after upgrading!. Same problem keeps happening to others not only me!
One claimed it could be related to brake system differences (ABS system and normal) and the brake pump could be sucking much air from intake manifold and that could confuse the ecu!
Is it possible? has any body experienced this problem before?
Help please.
Posted 28th Nov 2021 at 07:55
craig903
As far as I'm aware with the XU10 J4RS or more specifically with the Marelli 1ap ecu when changing the stepper you have to reset the ecu so that it relearns the stepper positions etc for a good quality idle
http://www.306gti6.com/forum/showthread.php?id=16861
208 GTI Owner
Posted 28th Nov 2021 at 11:04
Does the Citroen Xantia 2.0L XU10J4R use a Bosch ECU?
Posted 28th Nov 2021 at 13:42
FrancoSss
I tried to reset the ecu and nothing changed.
The ecu is Bosch MP5.2 - 63
Posted 29th Nov 2021 at 13:24
FrancoSss
The problem seems a general one. I met people have done the same and they have the same problem! Not only me!
Posted 29th Nov 2021 at 13:30
