displaying posts 1 to 2 of 2
Author Subject: Getting p**sed off... Gearbox removal
Macallan
Hey guys.
Ive removed all bolts and the clutch arm, and the drive shaft.. Gear levers are off, and all the wiring. Nothing on the outside is holding it Back.
The box is almost of, loose all around, but just wont let go.
Im removing it on the ground on some Jack stands, a hoist and so on.
Any advice? It seems the clutch fork wont let go even though ive remove the pin and the arm. As far as I Ca tell the fork shaft has turned some as I pulled the box away from the engine.
Do i need to pull the engine to get it off?
#puglife
Posted 7th Oct 2021 at 10:37
Macallan
Never mind... I got it . It was stuck on some wires under the inlet manifold.
#puglife
Posted 7th Oct 2021 at 12:00
