Author Subject: Replacement Fuel pipes
ProjectGTI 6
Advise please. Currently restoring a GTI6 and I am missing the fuel pipes from the tank and filter to the engine bay. Are these parts still available or is it best to make some up, suggestions would be appreciated or a set if anyone has them hanging about.
Phil Goodson
405 Mi16 Phase 1 until 2002
306 Gti6 current project car
405 Mi16 LeMans current project car
505 Gti Estate current project car
Audi S4 daily
Posted 8th Aug 2021 at 21:03
S8-Tom
I suspect anything from a petrol 306 would work, might be worth getting the fuel pump/sender and all of the pipework from a donor so you can see where/how it all fits together. The only difference would be at the engine bay due to the different fuel rail arrangements but, on a GTi6, it'd be a good move to switch to something that does away with the white and green cubes as they're a known source of leaks.
I've done this with mine, as have a few others.
Posted 9th Aug 2021 at 15:55
ProjectGTI 6
That is looking good and something that I am considering doing. What fittings and piping did you use on that set up and how far did you go with the new piping. My rother unning GTI-6 is not leaking from the squares so lucky there but will consider changing to something newer when I rip the engine out.
Phil Goodson
Audi S4 daily
Posted 9th Aug 2021 at 20:00
S8-Tom
The fittings are all AN-6 and use the PTFE lined hose. The pipes only go as far as the the chassis rail although I'd considered going all the way to the tank with these connectors at the fuel pump/sender & filter but it gets really expensive!
Posted 10th Aug 2021 at 13:44
ProjectGTI 6
Thanks for the info. Hopefully getting an original one from Dave Gilbert to put on but certainly looks the part.
Phil Goodson
Audi S4 daily
Posted 11th Aug 2021 at 23:12
