Author Subject: 1.4 8v to 1.8 16v engine swap
adamob
Hello recently on my 1.4 the headgasket went so decided to engine swap it to a 1.8, got all the bits including ecu, wiring, drive shafts etc. My question is can I unlock the segam ecu without the original car or wire in immobiliser from the 1.4 ecu into the 1.8? Thank you for your help
Adam Beczkowski
Posted 4th Aug 2021 at 13:59
What phase 306 do you have?
Posted 4th Aug 2021 at 14:01
adamob
It's a 2000 phase 3
Adam Beczkowski
Posted 4th Aug 2021 at 14:02
Joep
As it is a completely different engine, you need to swap the wiring harness and ECU as well. So everything from the donor car into the receiving car. Quite a lot of work.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 4th Aug 2021 at 14:48
oooblik
Filter housing
Posted 6th Jan 2022 at 17:07
oooblik
Not much work,
scythe. Engine , changes under the hood , which is in the wing , replacement of the control unit , replacement of the immobilizer unit , which is located under the clock where the stove is , the main drive shafts the number of teeth to match , replacement of the helicopter , replacement , wings , I personally went through alterations from the machine , to mechanics , at the beginning of hu10 al4 , then 1.4 KFW manual transmission , then , hu 10 manual transmission
Posted 6th Jan 2022 at 17:09
