Author Subject: Replacement Caliper / Brake Binding
justsamo
Evening all
After some help please?
Just failed MOT on a brake bind (OSF), I’ve stopped down the brake and cleaned it all up with brake cleaner, wire brush etc
One of the caliper pins had seized which I regreased and put all back together with fresh copper grease on the pads etc.
Still binding after a retest so can only assume I need a new caliper.
Trouble is I can’t find them anywhere down here in Plymouth nor can I find someone/ a company who would refurbish the caliper I have?
Does anyone know where I can get a new caliper or is there anything else I can try and get this sorted? (Just spent ages sorting all the other 306 woes…)
Cheers!!
Posted 22nd Jul 2021 at 17:06
justsamo
I did find this but I’m a bit sceptical…
https://m.autodoc.co.uk/budweg-caliper/1939759
Posted 22nd Jul 2021 at 18:23
I'd put a seal and piston in it if needed, I dont use copper grease any more, red rubber on the pins and ate pad slider grease
Posted 22nd Jul 2021 at 22:23
justsamo
Do you mean get one of those repair kits that come with the seals and piston etc. ??
Posted 22nd Jul 2021 at 22:58
Nose
If you can't repair it or find a second hand unit then have a look at a place in Worcester called Bigg Red, they will recondition your caliper for you, think they may also be able to offer you a rebuild kit for you to do yourself.
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 23rd Jul 2021 at 15:59
yes, ot drop them off to Ben at Godspeed for him to blast and powdercoat as well.
Posted 24th Jul 2021 at 08:38
justsamo
Thanks for the advice. Need the car sorted sooner rather than later so leaning towards a replacement caliper and then in time I’ll have a go at refurbishing the Lucas one.
What is the opinion on Budweg Calipers?
Posted 24th Jul 2021 at 11:07
