Author Subject: popping out of 1st
craig903
Hi all
My 1st gear is popping out, it feels as if something is hitting the linkages and knocking it out but even with the linkages off and 1st selected it pops out as you rock the car back and forth. All the time your throttling in 1st its fine when the clutch goes down that's when it happens.
Was apparently a good gearbox, obviously not. synchro issue right?
thanks
208 GTI Owner
Posted 25th Apr 2021 at 20:13
does it crunch going in or just pop out?
Posted 25th Apr 2021 at 22:20
craig903
No crunching or noises until it pops out. It pops out half way so you then get noise from the synchro not meshing properly. No noises whilst driving and all the time you have throttle it will stay in.
208 GTI Owner
Posted 26th Apr 2021 at 12:25
gypsyrover
Have you checked your engine mounts? In particular the lower mount.
Paul Clothier
Posted 28th Apr 2021 at 20:30
craig903
Yeah, I have uprated baker bm ones, I can't rock the engine myself and its only 1st gear
208 GTI Owner
Posted 28th Apr 2021 at 20:51
gypsyrover
Contaminated gearbox oil, worn syncros inside the transmission, or improperly adjusted shift linkages are very common reasons. The other being gearbox/engine mounts. What can also be a problem is if you have fitted the quick change gear selector if it is improperly installed or goes out of adjustment. The off throttle is the more usual moment for this problem to occur.
Paul Clothier
Posted 3rd May 2021 at 10:05
