Author Subject: New E10 Fuel
I've just looked a the Government website and it just says all petrol Peugeots made after 1st January 2000 are compatible so I assume all GTis are?
Posted 19th Apr 2021 at 16:33
alcon
The government website is pretty useless to be honest. My GTi6 was made in Nov 1999 yet according to this if one was made two months later (ie Jan 2000) then it would be compatible.
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 19th Apr 2021 at 18:13
Joep
Never use E10. It degrades the fuel lines. Even modern cars are getting more wear due to E10.
Peugeot Netherlands advised me to only put RON98 in my 110 bhp 308 from 2019... E10 was affecting performance and wear to much.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 20th Apr 2021 at 13:01
they will be fine, all unleaded fuel has been E5 since the 80's, apart from 2 very short pieces the 306 uses nylon fuel lines ao they will be totally unaffected.
Posted 20th Apr 2021 at 22:19
ben306
It something that will effect my Camper so will be looking to replace the lines on that with something more suitable/resistant, but dont think it will be a problem with the Rallye.
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 21st Apr 2021 at 07:28
Does it degrade rubber so might need new injector 'O' rings?
Posted 23rd Apr 2021 at 00:03
plain rubber yes, nitrile rubber or BunaN is very resistant, not likely that a 306 hasnt got nitrile seals but they are cheap, amd these cars are getting on a bit so its probably worth getting them serviced anuway
Posted 23rd Apr 2021 at 09:38
jimmyhackers
random but i thought id mention this, higher octane fuels can cause a gti6 (and othe cars) to misfire/behave badly.
octane isnt a power rating but a pre-detonation resistance rating (higher numbers meaning more resistance to pre-detonation)
Posted 22nd Nov 2023 at 17:15
Joep
Thought that is only the case if the engine does not have a knock sensor…
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 23rd Nov 2023 at 05:36
jimmyhackers
might of just been the asda fuel and their flavour of addatives...
but adding stuff to reduce explosion chance also means it might not actually ignite or only partially combust under lesser compresion engines (especially 20+ year old pugs)
Posted 23rd Nov 2023 at 18:49
These are 10.8-1, they arent lesser
Posted 24th Nov 2023 at 14:27
jimmyhackers
i meant a 20+ year old engine that started with 10.8-1 might be a little less now after 20+ years of wear.
no disrespect ment Smile
Posted 24th Nov 2023 at 15:20
jimmyhackers
went for a google for e10 fuel vs the 306.....found this thread id already polluted a few years ago.
found my answer....the only fueling parts you need replace for e10 proofing are the two short peices of hose on the fuel rail in the engine bay as welshpug said. (what i did today)
mine were cracked and crusty on the inside....looked fine on the outside.
probably contributed to why my return fuel line blocked.....kept flaking tiny bits of rubber into the fuel.
defo worth an investigation/replace if you havnt done so yet.
Posted 4th Apr 2026 at 12:29
