Author Subject: Sump Gasket??
eiei0
I was led to believe there is no sump gasket on the GTI engine, but I see Spoox sell one, I'm just after taking my sump off to clean it and reseal it as there is loads of leaks on it,
Is it worth a punt or should I just use some sealent, can anyone recommend a good one as I've never done this job before, need to do the cam covers as well but that's a job for a different day,
Thanks
Trevor
Posted 30th Nov 2020 at 17:46
aluminium sunp only needs sealant, the gasket was for the steel sump, though you can use sealant on them too.
I wouldn't buy it from spooks anyway, Autodoc or my local engine reman place or gsf even will be cheaper.
Posted 30th Nov 2020 at 20:57
eiei0
Thanks I haven't seen them anywhere else only spooxs so sealent it is then,
Posted 30th Nov 2020 at 23:23
thats because this engine never used them, so nobody will list one.
look under diesel or 205 and you will see them
Posted 1st Dec 2020 at 07:46
