Author Subject: Gearbox plugs and washers
eiei0
Hi All
I'm after a bit of help, I can't seem to find all the info on the manuals,
There is 3 plugs on the gearbox one is the drain at the bottom one is on the back of the diff housing, and there is the check level up at the 6th gear bludge,
Has anyone the part numbers for these and the washers for them
Thanks
Trevor
Posted 19th Nov 2020 at 22:38
davidmartin
I think this is the diagram and numbers you are looking for
Clicky
pet hate, the cat
Posted 21st Nov 2020 at 18:05
eiei0
Thanks when I drained the oil I didn't use the one on the back of the diff housing I used a plug along the bottom, so there is 3 places that you can open to drain/check the oil and then you can fill it through the breather,
I will have to look at the gearbox and see as the diagram doesn't call out the one I used to drain the box, or at least I can't spot it,
Posted 21st Nov 2020 at 20:33
I've a pack of 2538.10's washers for sale, item 17 from clicky provided above that you'll need.
Posted 21st Nov 2020 at 23:21
eiei0
Thanks for the offer but the cost of postage to Ireland would be more than what they are worth, At least I now know one of the PN's I need,
Posted 21st Nov 2020 at 23:31
No worries hadn't spotted your location tbh.
Posted 21st Nov 2020 at 23:52
there's only one drain plug on the diff.
Posted 22nd Nov 2020 at 08:39
