Author Subject: Piston ring gaps
S8-Tom
I've been measuring my crank and piston rings today to make sure everything's ready to be put back together when I get the head back.
I've bought Goetze rings (part 08-306800-00) for a Vauxhall C20LET engine as these have been widely used by others for the J4RS engine.
I'm getting 0.5mm on the top ring and 0.45 on the second/middle ring. This is pushing the upper range of what Haynes suggests and I think I've read on here that 0.3-0.35 is typical?
Posted 30th Oct 2020 at 15:31
your block is probably a bit worn out! quite typical of these blocks.
Posted 30th Oct 2020 at 19:11
S8-Tom
I think that's the reality of it. I'm sure this car hates me. The block in question has 80K on it and was measured with a dial bore guage, appeared to be good but clearly wasn't thorough enough with the measurements! Shame, it's been decked and honed already Thumbs down
Looks like I'm back to the original block and an overbore then. FFS Wink
Posted 30th Oct 2020 at 20:02
What pistons will you be going for with the oversize bore?
Posted 30th Oct 2020 at 23:12
S8-Tom
Found these ones from Mahle. The 06xxxx are the corresponding Peugeot part number. The first oversize is NLA from Peugeot but in any case, they're twice the price of the Mahle items.
Posted 31st Oct 2020 at 08:25
Cheers for that, may have to get a set if my suspicions are true on one of my engines.
I thought they'd be more expensive than that to be honest.
Posted 1st Nov 2020 at 20:14
S8-Tom
Even better price from here!
I've been talking to them and they've confirmed they can be ordered and that they're suitable for the XU10J4RS
I've ordered 4 @ £275.92 shipped to the UK.
Posted 2nd Nov 2020 at 08:48
Cheers for sharing that info Thumbs up
Posted 2nd Nov 2020 at 20:34
S8-Tom
Pistons arrive this morning. Less than a week from ordering and tracked right to my front door within a 1 hr time slot!
Posted 9th Nov 2020 at 11:11
ideal time to make those cutours +1.0mm Big grin
Posted 9th Nov 2020 at 16:56
S8-Tom
Impact on compression with larger bores AND valve cutouts? Head will have a small amount taken off (currently at 136.91) and block decked. There's also the argument of mapping or not with cams Dunno
Posted 9th Nov 2020 at 19:02
