Author Subject: Wishbones/Control Arms
Qbar56
Could anyone tell me if the GTI6 front wishbones are a different spec than those on the standard 306?
Looking for the 16mm version, Russian site part numbers appear to be 3520H4-Left and 3521E4 Right.
Were these numbers superseded?
Most sites will list only for the S16 or XSI.
Any knowledge would be great,
Cheers,
Tony
A Barkwith
Posted 16th Oct 2020 at 02:53
Joep
If I were you, I would measure which size you have on your car now. If I recall correctly, 16mm is standard for most GTI models, but some are fitted with 18mm. French logic...
S16 and XSI have 18mm.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 16th Oct 2020 at 06:44
davidmartin
Those are the correct numbers, those o.e arms do not have the ball joints attached part number for the 16mm ball joints is 364037 ( part numbers for the arms are different on the non sport models ) beware of the aftermarket ones as most have riveted on ball joints so check sizes on them.
Cheers,
Tony
pet hate, the cat
Posted 16th Oct 2020 at 11:15
Ben_W
Formerly gpm
16mm ball joints were on the earlier cars, certainly on the GTi6. Sometime in 98 I think it was they changed to 18mm for the rest of production (might have been with the change to Phase 2 but I can't be sure...)
Posted 17th Oct 2020 at 09:40
phaee2 was 97, it did not change then.
there are also 2 types, non oas and pas, they give different amounts of camber, pas having more.
too mounts are also different to give less castor angle.
Posted 17th Oct 2020 at 09:55
Joep
I have a late ‘99 GTI with 16mm... found out when I changed the wishbones earlier this year.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 17th Oct 2020 at 11:47
eiei0
I'm looking to change my top mounts as I build up a set of B8's
Looking on the usual parts places they only seem to list one type of top mount, how do you work out what one is needed,
I don't know what size ball joint I have as I haven't split them yet, but it's a ph2 98 car,
Thanks
Posted 17th Oct 2020 at 12:17
