Author Subject: Wiper Problem, no self park & 1 speed. PH1 DT to PH3 GTi6
MartinT90
Hi guys, I have been converting a PH1 DT to PH3 GTi6, I had replaced the whole front wiring from PH1 to PH3 (engine bay & under dash) Everything works fine except the wipers. Now I have 2 stalks one with the auto & one without & 2 wiper motors both tested. The problems are;
1. No self park
2. Only have 1 speed (the slow & the one hit one swipe)
Now I'm aware the the PH1 had a blue relay behind the fuse box & the PH3 doesn't have. & also I'm getting mixed suggestions on the NET. Can you help me out Please? I'm desperate to finish up this car.
Posted 6th Sep 2020 at 18:06
the dash loom is different for ph3, they also have a rain sensor.
Posted 6th Sep 2020 at 21:40
MartinT90
As i said in my post, the wiring loom of the dash is PH3. Do you think the problem is persisting because of the missing rain sensor? & how can I find the wire of the sensor with in the loom it self? Thanks.
Posted 7th Sep 2020 at 16:20
Joep
Phase 3 should also have the blue relay, if my memory is not failing me.
You cannot use an “auto” stalk when the sensor is missing.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 7th Sep 2020 at 17:51
MartinT90
I dont think so(still not sure) the only blue relay I had is at the rear motor wiper. I couldn't find any sockets that fit a blue relay behind the fusebox, but I did have one on the PH1 loom. I also switched between the stalks & still same results. loosing my mind on this problem, it's the only thing it keeping me back from putting this car together so I can enjoy it. Cry
Posted 8th Sep 2020 at 09:17
that system has 2 relays from memory, not just 1.
Posted 8th Sep 2020 at 11:54
MartinT90
Can you specify which are these 2 relay pls. Thx.
Also i have the non auto wiper stalk installed.
Posted 12th Sep 2020 at 08:08
S8-Tom
It'll be the 2 purple relays next to the fuse board under the steering wheel.
Have a look in the FAQ section, under 'Electrical', for Phase 3 fuse box
Posted 12th Sep 2020 at 08:24
MartinT90
Pinterest links
https://i.pinimg.com/originals/ca/bc/51/cabc51e78facc9982153cf64adf0dcc8.jpg
https://i.pinimg.com/originals/f9/cc/3e/f9cc3e7b68e616c1e15963395b501aef.jpg
Correction on my end. The wiring is PH2 according to the date on the fuse box, which make the wiring mentioned before a PH2.
I said a PH3 because the Halfcut I got the wiring from was a PH3 front end with rounded fog lamps. maybe somwhere along it life preuios owner changed it to PH3 bumper.
Posted 12th Sep 2020 at 12:00
S8-Tom
It all gets a bit confusing. P2 GTi's were the first model to wear the bumper with round fogs. All other P2's had the crappy bumper with the 'D' shaped fogs.
All P3 cars, regardless of model, ended up with the round fog bumper.
I think that's right but happy to be corrected.
Posted 12th Sep 2020 at 15:03
yep all ph2 and 3 gti'd had round fogs.
Posted 12th Sep 2020 at 21:08
