Author Subject: Gearbox options high boost
a1rak
Hi guys just stripped 3rd gear on my high boost. Can anyone advise on what the best options to stop this happening again. I know there is an upgraded gear set for the 5 speed box but been +quoted £3.5k for the upgrade fitted and running. Would love to stay six speed but its probably not an option. Guessing the engine is around 330bhp. What about the ML 5 per box out of a 406. Really appreciate any advise.
Posted 17th Aug 2020 at 10:47
unless you are able to do all the fab work yourself then a dog kit from Maximotoraport is likely to be the cheapest strong gearset still in a be casing.
going ml incolves subframe mods, custom driveshafts and fitting a cable shift assembly.
diff for an ML is more expensive and harder to fins too.
Posted 17th Aug 2020 at 12:37
craig903
There are not any Peugeot gearboxes that will happily take the power. A conversion would set you back probably 2/3 of that quoted price. incl a custom flywheel and clutch, shafts, new lsd, and gear linkage change/clutch pedal cable/hydro conversion
208 GTI Owner
Posted 17th Aug 2020 at 23:15
pete_rallye
I'd look at a box from something like a focus ST/RS, Megane RS, Honda boxes seem to be strong too basically something high power and FWD, and ideally readily available. Yes it'll cost you for a custom bellhousing but if you spend £3k on a proper conversion to something designed to take the power and torque it should last you ages. If you get a few people together too it'll dilute the cost nicely too.
Lap of the 'ring
Posted 17th Aug 2020 at 23:34
James306
Hi, i thought i would have a look haven't been on here for a lil while mainly facebook group thought i would share my super high boost gearbox project
https://www.facebook.com/groups/306FanClub/permalink/10157646261156016/
Posted 29th Nov 2020 at 00:38
Fantastic James ....good luck with it mucker Thumbs up
Posted 29th Nov 2020 at 10:04
James306
Thanks mate hope to have it ready for early show season i hope its the solution
Posted 30th Nov 2020 at 18:08
