Author Subject: GTI 6
dudley1996
Hi all,
Im looking for a 6, have had one before a silver one, am not sure if anyone knew about it on here but was just an awesome car.
Want a bit of a project, so any cars that may need some work is cool, they need to at least run, drive and be able to be driven away rather than towed.
As well as the 6, im also going to want a Scorpian backbox, 4-2-1 manifold, adjustable fuel pressure regulator, silicone long elbow intake pipe with a filter (Either K and N or Piper Cross)
Eventually, I think I will go down the cams and throttle body options, anyone got any advice for that?
Cheers guys
Scott
Posted 11th Jul 2020 at 08:32
dudley1996 wrote:
im also going to want , 4-2-1 manifold, adjustable fuel pressure regulator
no, you really dont, they have a VERY good 4-1 as standard, you have to be really pushing the envelope of engine builds to need to change the manifold.
as for an Adjustable reg, they are utterly pointless, the standard vacuum referenced fixed pressure 3 bar unit works just fine, you wont gain anything from adjusting the pressure, if you need more fuel get the map altered.
Satchell engineering do a very good kit for the throttle bodies, cams you have to be very careful as there is very little clearance in the standard piston to allow the valves to open earlier, they can be modified by Bridgecraft motorsport engineering to make mild upgrades safe, if you want to go further then you're talking about pistons rods and valve springs.
this thread has lots of information on the cams you can and can't fit.
http://www.306gti6.com/forum/showthread.php?id=104146
Posted 11th Jul 2020 at 11:05
Mine will be for sale soon, high miler but good. Maybe best as a breaker as right wing isn't the best.
Posted 12th Jul 2020 at 16:10
Laytj
Is this car available now?
L james
Posted 22nd Jul 2020 at 11:37
Laytj
L james
If referring to mine. It's provisionally sold already.
Posted 22nd Jul 2020 at 22:01
