175000 K's with 10 years of service records. Water pump and timing belt done at 156000. I don't have a pic as yet but will get to it.
Are the heater matrix hoses available?
Cheers.
G F Hesp
| Author | Subject: Newbie saying Hi |
hespie
Newbie Location: Shearwater Registered: 06 Jul 2020 Posts: 6 Status: Offline |
Thanks for the join. I have a 98 GTI6 in Tasmania Aus. Bought from my son as he wanted to move it on. Cracked windscreen, heater matrix hoses need replacing and a muffler!175000 K's with 10 years of service records. Water pump and timing belt done at 156000. I don't have a pic as yet but will get to it. Are the heater matrix hoses available? Cheers. ________________________________________ G F Hesp |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
Only available second hand.What's wrong with it? ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
hespie
Its has a leak!________________________________________ G F Hesp |
Have you tried new 'O' rings?________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
Nose
Senior User Location: Birmingham Registered: 23 Jun 2013 Posts: 994 Status: Offline |
Hi Gerard and welcome sir. It'll probably the unit itself bud, it's a common problem with our cars i'm afraid. Luckily they're not expensive - bad news is it's a s**te of a job to do. Although i actually found mine was quite easy to do - as i paid someone far more technically advanced than myself to do it It's also great to have someone actually a bit older than me on here, ok it's only 4 years but i'll take that.cheers ________________________________________ Bianca 306 Rallye.Mondeo Titanium X. |
hespie
Thanks Nose, hanging onto my 50's just. I'm yet to see where the leak is but my son told me one of the two hoses had a split in it, I'll be investigating this weekend.________________________________________ G F Hesp |
Get some metal pipe, cut hose, and join?________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
pug_306
Seasoned Pro Location: Great Hockham Registered: 28 May 2013 Posts: 1,597 Status: Offline |
Hi buddy I've just sent a set of heater hoses to Australia. I can do it for £80 inc del.Regards ________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
Welcome Gerard ...Hope you will find the site useful |
hespie
Thanks Guys, washed her yesterday, 6 months of sitting under some trees, needs a polish now.________________________________________ G F Hesp |
hespie
Ive had it running and the coolant is dribbling from the plastic joiners between the hoses and the firewall where it joins the heater pipes i presume. Are there O rings in those joiners/connectors?________________________________________ G F Hesp |
Joep
Senior User Location: Urmond (The Netherlands) Registered: 19 Sep 2013 Posts: 501 Status: Offline |
Yes. there should be o-rings. Not easy to get them fitted correctly though... On one of my cars, the o-ring is not sitting properly, so it is leaking slightly.________________________________________ My car park:'96 Sigma Blue XSi6 '98 Diablo Red GTi6 '99 Onyx Black S16 All RFS powered! Plus various other Peugeots |
hespie
Thanks Joep________________________________________ G F Hesp |
