| Author | Subject: TPS replacement price! |
Tomspeight
Newbie Location: Otley Registered: 06 Jun 2020 Posts: 9 Status: Offline |
I think Im looking at the correct part for a replacement Bosch TPS part no. 0 280 122 009 and wow they are a load of money! Cheapest I can find is £187! Does anyone have any experience with the Vemo branded ones? They state they are Oe spec. |
ive used an s16 one, different part number, black, but same bolt pattern and resistance range I'm sure.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Nose
Senior User Location: Birmingham Registered: 23 Jun 2013 Posts: 994 Status: Offline |
There are a few on ebay in Bosch which are cheaper Tom - only by about £30 ish. You could always take the Bosch number into your local motor factors, they will be able to cross it over into other cheaper brands for you. I'm still on furlough at the moment otherwise i could have helped you with some equivalent part numbers from other manufacturers. Good luck.________________________________________ Bianca 306 Rallye.Mondeo Titanium X. |
Tomspeight
Cheers guys. I might try my local motor factor like you suggest. I do always try and go original if possible but that price just seems mental. |
davidmartin
Seasoned Pro Location: Beautifull Ystalyfera Registered: 21 Oct 2006 Posts: 3,316 Status: Offline |
I've got a few intermotor ones here if you want to give one a go. I could do one for £15 delivered ( flattened down box to keep p+p cost down )________________________________________ pet hate, the cat |
I wonder why the price has gone so mental, i bought a genuine Bosch one from ebay in 2018 for £62 delivered, same part number as above.________________________________________ Goldie the track car. |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
https://www.doctorcarparts.co.uk/280153-bosch-0-280-122-009-sensor-throttle-position.html________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
