Author Subject: Brake system parts
eiei0
Hi Guys
I'm looking to start to order parts to rebuild my brake system, not having much luck finding parts,
Can anyone point me in the direction of some of the harder to find bits,
Master cylinder
Rear compensator
Is there any direct fit alternatives out there,
Where is the best place for caliper refurbs,
Thanks
Posted 16th May 2020 at 09:48
Ben_W
Formerly gpm
Are you after new?
I think both the MC and the rear compensator have been discontinued by Bosch, there may still be residual stocks out there.
Seem.to remember a VW T4 MC being touted as an alternative, but don't quote me on that one, because I might be getting mixed up with something else ..
Posted 16th May 2020 at 10:31
eiei0
New ideally yes,
Posted 16th May 2020 at 10:44
eiei0
I've see the T4 mod but it's not direct fit think it needs a bit of faffing around to get it to work, not keen on this with the brake system it's kinda important 😁
Posted 16th May 2020 at 10:46
https://www.brakesint.co.uk/ used these guys a fair bit for rebuild parts, seems their online shop is down right now but they're really helpful over the phone.
the load compensator I think you will struggle with, but you you have one which isn't seized solid or leaking then keep it.
master cylinder should be easy to find, its the same bore as every 406.
Posted 16th May 2020 at 13:18
eiei0
I wonder is there an equivalent fitted to any other models,
There is some showing on eBay for different models of Peugeot some don't seem to have the spring I wonder could you make one from 2 so to speak,
If it's like this to get bits for a 306 a 205 must be a nightmare,
Posted 16th May 2020 at 13:49
S8-Tom
Bigg Red do a master cylinder rebuild kit. They also do brake refurbs.
Posted 16th May 2020 at 15:09
eiei0
Are they any good was thinking of sending my calipers to them??
Posted 16th May 2020 at 16:48
S8-Tom
Had a few bits from them but never had any calipers refurbed.
Posted 16th May 2020 at 17:03
205 is still easy enough to find bits for, most of the brake components were used on lots of other french vehicles, Clio was one, same calipers front and rear, VW golf used the same master cylinder.
only thing that is hard to find is the 1.6 pressure limiter though they are reliable things, the 1.9 ones are still available.
the gti6 load compensator is specific, though I'm not sure which part of it is, the valve itself or the spring.
Posted 17th May 2020 at 08:54
eiei0
Lots of valves look very similar just the spring section is quiet unique,
Are the ports 4 x m10 or 2 x m10 and 2 x m12
Posted 17th May 2020 at 09:58
eiei0
What differences would there be in the LHD Master Cylinder Brembo still list a 4601 F6 equivalent but nothing for the F7 that we need for RHD,
https://www.bremboparts.com/europe/en/catalogue/hydraulic/M_61_046
Posted 20th May 2020 at 05:20
eiei0
Is the 2 ports M10 or is the one nearest the servo M12 can anyone tell me ??
Posted 20th May 2020 at 15:37
eiei0
Look what I got from eBay brand new old stock by the looks of it, has the right Bosch part number and all,
Posted 25th May 2020 at 07:52
Joep
Good find!
I am so happy phase 3's do not have one. Was afraid I had to source one when getting the new rear axle fitted...
I would spray some Eurol ML coating spray on it. Prevents oxidation!
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 25th May 2020 at 08:10
What's the part number?
Posted 26th May 2020 at 13:33
eiei0
Bosch 0204131271
OEM 486185
Posted 26th May 2020 at 19:21
How much did you end up paying?
Posted 27th May 2020 at 00:18
eiei0
Think it was about £100 so not too bad,
I hope to be able to refurb my own and keep it as a spare,
Posted 27th May 2020 at 03:56
