Any ideas as to if the new one is correct for GTI or what the old one is off? I know the car had a new door at sometime😔
Stuck now with no window mechanism fitted
New on left & correct part number, old on right.
Motors
Old motor in situ
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
There's two makes, I thick Bosch and Valeo.I went to change mine and found an adapter cable for the different connector but the replacement screwed in okay. ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
mellowr1
Senior User Location: Maidstone Registered: 12 Jun 2012 Posts: 995 Status: Offline |
Unfortunately mine just won't seem to fit even though a genuine correct part the brackets on the 2 mechanisms look to be in totally different places |
fair chance its the wrong assembly in the bag/box with how long these cars have been out of production, possibly a cab mechanism.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mellowr1
welshpug! wrote: fair chance its the wrong assembly in the bag/box with how long these cars have been out of production, possibly a cab mechanism. It was from peugeot parts uk. I'd hope they would send correct part wouldn't all 306 3 doors and mechanisms be the same be the same? |
that place used to be called Dean Hunter from memory, originally an oem peugeot parts distributor before peugeot bought it into one massive warehouse.these days I think they buy up old stock from dealers, so its very possible the packaging got damaged or the label fell off. 306 cab windows are very different, they are frameless for a start! and have a quarter light. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mellowr1
yep that's him, Dean.The part number on the sealed bag is correct. Genuine peugeot label and part number. As for the doors being the same i meant all 3 door door skins/internals with full window frame must have the same holes for mech to mount in? God knows what is going on with it. I'm just off outside to stare at it for another day |
drop them an email with pics, quite evident its not right.there were changes in assembly and brands but all the holes were in the same place, plugs changed, late ones were rivetted not bolted. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mellowr1
I rang dean. He checked all part numbers and looked at pictures i supplied. He was going to check another door but i think i have cracked it now Thank you for all your help guys |
mellowr1
All fixed now thanks men. Goes up and down now and auto down works👍😎 |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
________________________________________ Proud Member of the ASTOR Owners Club |
alcon
Senior User Location: Glasgow Registered: 19 Jan 2005 Posts: 941 Status: Offline |
mellowr1 wrote: I rang dean. He checked all part numbers and looked at pictures i supplied. He was going to check another door but i think i have cracked it now Thank you for all your help guys Well?....what was the outcome?....how did you crack it?? ________________________________________ 1999 GTi-6 (china blue)1999 Rallye (black) |
