Author Subject: Dutch Track Day 306
Joep
Hello,
As I always wanted to have my own track day car, I decided to turn my German GTi6 (S16 in Germany) into one.
Last year, I first collected some lightwheight C5 aluminies and some Nankang NS2R tyres:
Then I went to the Nurburg Ring.
That tasted like more! So, then I bought some additional goodies: OMP upper and lower strut brace, de-cat from Spoox, straight pipe from de-cat to Remus back box.
The lower strut brace still has to be fitted...
Then I went to the TT circuit in Assen where I did some laps with an instructor first. After lunch I went on the track where a absole c#nt in a rented BMW missed his braking point and slammed into my car!
But, this does not mean I quit! In contrast: a friend of mine has quit his track day car project and sold me his upgrade parts:
- GAZ Gold adjustable coil overs;
- BakerBM adjustable top mounts;
- GAZ Gold adjustable rear dampers;
- Xsara-306 revised rear axle;
- Peugeot Sport (?) roll cage;
- Peugeot Sport rear brake disks.
GAZ Gold with BakerBM adjustable top mounts. Never fitted
Roll cage and in the back the Xsara-306 hybrid axle
And from other sources, I collected: front wishbones with Powerflex Black P-bushes and Powerflex Purple front bushes, deepdish steering wheel with boss, OMP seat bases, door straps, and some other bits.
So, now we are in lock-up, I decided to do some work on the track day car:
Coil overs that are currently fitted. Most likely V-Maxx
While I am at it, will change these as well
This pipe needs to be replaced. Will fit an oil catch can as well
Even this unit is leaking
Wheight reduction:
The window control unit, I want to fix in the space for the speaker
All the plastic trims have come off as well
Removed everything in the rear
Seats out
The wire mess from the Gemel alarm
Rear part carpet: out
No idea what this connector is for
Bit of water under driver seat
Are these for the side airbags?
Again: sh!t load of wires from the alarm
End result so far
Gave the cars a good wash yesterday
Next on the list: Removing current coil overs, creating a bit space for the BakerBM top mounts, fitting GAZ Golds. While I am at it: change old droplinks for new, and wishbones for the one that has the Powerflex bushes fitted.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 29th Mar 2020 at 14:22
Joep
Not sure why the photos are not loading...
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 29th Mar 2020 at 14:30
Wilde Haren
Looking Nice Joep!
Assen is a great circuit to start off on; nice and flat and lots of run-off space!
Come practice at Wimedo when you (and the lockdown) are done.
PS. Now I need to add a cage to my list too ;-)
Posted 29th Mar 2020 at 14:34
blandy
Looking good
Posted 29th Mar 2020 at 14:37
Joep
@Sander: yes. The run off space I needed for sure during my first laps 😝 and when the BMW hit me 😡
Want to go to some more tracks. But I will be mainly at the Ring as it is within an hours drive. Wimedo, is that always open?
@Mike: thanks! The rear bumper of your black car will be an example how I want to make mine. But then with the exhaust at the standard spot.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 29th Mar 2020 at 15:02
Wilde Haren
Wimedo is an autocross event at Midland Circuit Lelystad, about an hours drive for me ;-)
They host about 10 events each year. You pay a few bucks per lap, your fastest time of the day scores points for the championship. Best 6 laps are used at the end of the year to see how big a trophy you get.
See their website or YouTube or Instagram
I guarantee you'll have fun, not just driving but also chatting with like minded people and just watching cars.
Posted 29th Mar 2020 at 16:59
Joep
Over the last week I removed the VMaxx coilovers (might go on my girlfriends 206 SW now) and fitted the BakerBM adjustable topmounts with the GAZ Gold adjustable coilovers (photos will follow).
One question that I hope one of you might have the answer to: how do I set the correct preload of these coilovers?
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 7th Apr 2020 at 10:49
Wilde Haren
Hi Joep,
My Apx coilovers don't allow preload setting. It's just height and damping. Height I did by eye, damping I set to soft for daily use and hard for track use. Camber is set to -2.5 degrees for autocross use. So far the outside of my tires are still showing more wear than the inside.
Posted 7th Apr 2020 at 13:26
Joep
Then it might be the same for the GAZ ones...
I am just going to wind the lower ring up to the point I cannot move the spring. Then I wind it up 5mm more before I fix it with the locking ring. That is how it was explained on YT, but that were different coilovers...
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 7th Apr 2020 at 17:39
Joep
Car is back on its wheels again. A bit higher than with the VMaxx coilovers fitted, but let's see if the GAZ Golds have to settle...
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 7th Apr 2020 at 20:12
blandy
The gaz will be the same as the old coil overs in terms of adjustment - adjusting the collars will adjust the height. You’ll get the height etc set fairly easy but after having mine set up and corner weighted recently I’d really recommend spending the extra and getting it set up, easily the best and most cost effective thing I did on mine in terms of track driving
Posted 7th Apr 2020 at 20:31
Joep
That is for sure on my list Smile But first the Xsara-306 Hybrid rear axle has to be fitted Wink
Before I fitted the "new" wishbones with PowerFlex bushes, I cleaned them and gave them a bit of paint:
Old vs. new
Old ones are quite worn...
In contrast to fitting them on the convertible, fitting them on the S16 was very easy!
Then I took the Vmaxx coilovers off. Apparently, those are 206 coilovers. At least, that is the information one gets when looking up the product number.
GAZ ones look way nicer!
Next: pre-fitting the BakerBM topmounts to see what I had to cut away to make use of them.
Used a Dremel to cut away the metal that was in the way.
Do not look at the copper grease... I cleaned it now Wink
GAZ Golds fitted!
As mentioned, yesterday evening I put the car on its wheels again. But first I fitted the MOOG steel droplinks, Febi outer tie rod ends. Now everything is new at the front!
Last weekend I also did an oil and oil filter change and changed the fuel filter.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 8th Apr 2020 at 07:13
Joep
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 8th Apr 2020 at 14:16
Wilde Haren
Ominous looking!
Posted 8th Apr 2020 at 17:11
99rallye
That looks sinister. The front end should feel crispy fresh now
Posted 11th Apr 2020 at 08:56
Joep
Feels way better. It is not bouncy but comfortable and riggid. Have the coilivers set to the softest setting.
What I do feel is that the back suspension is not in line with the front suspension. I am looking forward to have the hybrid rear axle with GAZ dampers fitted!
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 11th Apr 2020 at 09:21
Joep
Some updates:
Last weekend I removed the headliner as well as the sun visors so the roll cage can be fitted.
Also removed the rear wiper as 1) I do not use it 2) it never works well 3) weight reduction:
Took all my tools out of the car:
And put the Xsara rear axle in:
Yesterday, I went to the fast Peugeot expert (approx. 200km drive) for the Dutch variant of the MOT and
to have the rear axle fitted.
Apparently the old axle was completely stuck as a result of the bump by the BMW. Unfortunately, I have no photos of how the bearings were pushed out and everything was rusted solid.
But now the Xsara axle is fitted. We were not sure what ARB was used during the rebuild of the axle, but for sure thicker torsion bars. Also, solid mounts were used:
Everything looks way more rusted than it is in real life. So no worries there.
What was also a big question, was what the ride height would be. My mechanic did not remember if he had set a height already. So, we just fitted everything and then lowered it:
Perfect!
What I found quite interesting is that the phase 3 GTI6 does not have a brake bias compensator. Apparently not needed?
We set the GAZ dampers on the rear at 15 clicks from zero (36 clicks in total) and I drove off. When there are some dips on the highway, the rear tyres rub... so maybe a few clicks more will be better.
Next up: PhillipM lower strutbar, body repair, cage fitting.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 30th Apr 2020 at 12:35
I think the phase 3's got rid of the compensator and used ebd instead.
Posted 30th Apr 2020 at 16:45
Wilde Haren
Looks like we have the same mechanic :-D
Both fast (car) and quick (mechanic) !
Posted 3rd May 2020 at 18:16
Joep
Just dropped off the car to have the bodywork fixed. Did not announce my visit... but that was okay.
Quickly informed about my restoration project (is at the body shop for 3 years - two weeks :p ):
"I was just about to call you as we painted it last week. Only need to clean it and then we build it up, partially (this was agreed on)."
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 20th May 2020 at 08:59
3rd time lucky
Interesting stuff going on here. Keep up the good work.
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 20th May 2020 at 16:16
Joep
Thanks!
Forgot to mention I have the PhillipM lower strut brace fitted now. Only 2mm play with engine...
The two orange/brown droplets you see on the right hand side are from the under coating (some sort of wax to protect the underside of the car).
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 20th May 2020 at 18:24
Joep
While the car is at the body shop, I made a nice purchase:
Acquired OMP seatmounts a while ago already. Now these lightweight OMP seats became available at a very fair price! Includes 4-point harness in red. Perfect as the color scheme will be black with red accents.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 15th Jun 2020 at 18:57
eiei0
Good progress look forward to seeing more details soon,
Posted 15th Jun 2020 at 23:12
Joep
Yesterday, I got my car back from the repair shop. The damage was way more work to repair than they anticipated. Good we made a price agreement upfront Smile
So, yesterday evening I wanted to fit the OMP seat bases and seats... If I use the prefab holes, the seat is about 10cm to far out! So, that will need some drilling of additional holes in the base.
But, then I realized that I cannot use the standard belts as the connector is fixed to the original seat! Now I first need to find someone who can weld in my roll cage and read up on how to fit 4-point harnesses. I know the belt that runs over your shoulder can be fitted to the horizontal bar of the cage, but where to fit the other two belts that run over your legs?
Any example is welcome! Also any tips and tricks on fitting the seat in the right position.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 7th Aug 2020 at 07:38
