Author Subject: Eccentric bolts
alcon
Does anyone know if the two eccentric bolts that go through the bottom engine mount are meant to have slight bends in them?.....or are mine knackered??
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 3rd Dec 2019 at 15:25
alcon
1999 Rallye (black)
Posted 3rd Dec 2019 at 15:38
Ax16v
These supposed to be straight, were probably over tightend a bit. Nothing to worry, just hammer them straight!
Make sure you clean the inside of the mount very well so that the bearing sits correct/flush, and doesn't have any dirt trapped between the bearing and the mount itself. And don't over tighten!
Posted 3rd Dec 2019 at 17:45
as mentioned, meant to be straight!
they only hold the bearing/shaft in place, very little force goes through them.
Posted 3rd Dec 2019 at 18:16
alcon
thanks, so not worth trying to replace?......just bend them back and don't over tighten, sounds easy enough
1999 Rallye (black)
Posted 3rd Dec 2019 at 20:18
