| Author | Subject: MAP Sensor values in Lexia? |
Bakov
Newbie Location: Sofia Registered: 04 Aug 2018 Posts: 11 Status: Offline |
Hello i want to know is this normal or not, in Lexia i see 0970mbar, in weather sites atmospheric pressure in my city is 1020mbar, when i start engine values are near to 330mbar/idle. In last two months I have issue, sometimes my engine cut off, MAP Sensor was changed and values was the same, before one week i found damaged wire, the wire was fixed and values that i see now are this https://www.youtube.com/watch?v=eYIzvxxglHA ,atmospheric pressure in my city at the moment was 1019mbar but engine problem is not fixed. Between MAP`s pins 2 and 3 i have 4.9V, Can you tell me is this normal to see differences between MAP values and real atmospheric pressure and how much. Thank you and sorry for my English |
aircool
Newbie Location: Near Exeter Registered: 11 Apr 2016 Posts: 27 Status: Offline |
MorningDon't rely on a weather forecast site for current atmospheric pressure as it is measured at a point not near your self and potentially at a different altitude and different time (its probably cached and provided every 15 minutes). Does the car drive ok? |
map value is for the intake manifold, so nowhere near atmospheric as thees an engine sucking air in past it.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Bakov
After ECU reset everything is fine for a while , but when the engine warms up 70 degrees or above, sometimes rpm at idle goes up and down with 50 rpm or stuck at 1100. ICV is brand new. Can you tell me what are normal values from MAP sensors when engine is not running |
miki4
Regular Location: Cologne Registered: 09 Nov 2015 Posts: 393 Status: Offline |
Do you still have the problem with the engine cutting out? When does that exactly happen? Just staying in idle or when disengaging the clutch e.g. while approaching a crossroad?Is that a genuine Marelli ICV? Your MAP values seem right so I wouldn't focus on them although it could still be an (intermittent) wiring issue. If you only have problems in idle and it's running fine otherwise, everything MAP related should be okay! Have you checked for air leaks after the throttle body? |
Bakov
The ICV is ERA and my problem is not fixed yet...engine cut off after 60 degrees, sometimes at idle sometimes at high RPM. Тhe diagnostic tool cannot find any fault, |
IvayloPavlov
Regular Location: Sofia,Bulgaria Registered: 06 Aug 2012 Posts: 265 Status: Offline |
MAP value ~ 0.94 when ignition on or full throttle+low RPM and 0.35 at idle. If decelerate you can see even as less as 0.15 value. |
miki4
What exactly do you mean with cut-off? Maybe you could upload a video. I mean, at high rpm the engine still rotates. |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
miki4 wrote: What exactly do you mean with cut-off? Maybe you could upload a video. I mean, at high rpm the engine still rotates. He means the engine stops firing so no throttle response so it dies. ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
Bakov
miki4 wrote: What exactly do you mean with cut-off? Maybe you could upload a video. I mean, at high rpm the engine still rotates. 0:24 https://www.youtube.com/watch?v=BU3Ydy8djuo |
Joep
Senior User Location: Urmond (The Netherlands) Registered: 19 Sep 2013 Posts: 501 Status: Offline |
Does not sound like a ICV issue. Sounds more like it is restricted in fuel flow or something like that.Starts normal? Did you change the fuel filter? And in the movie from the opening post I see that air temp. is over 40°C. That is quite hot. But I am not an expert on these values, so maybe someone else can tell us if this is normal yes/no. ________________________________________ My car park:'96 Sigma Blue XSi6 '98 Diablo Red GTi6 '99 Onyx Black S16 All RFS powered! Plus various other Peugeots |
Bakov
The car starts normal. The fuel filter is new.The air temp is too high, I have not seen values like these before |
Joep
I would change the sensor that measures air temp.________________________________________ My car park:'96 Sigma Blue XSi6 '98 Diablo Red GTi6 '99 Onyx Black S16 All RFS powered! Plus various other Peugeots |
miki4
You could also try and just unplug the sensor. The ECU does only minor corrections based on the value from the air intake temperature sensor.Keep in mind that there is also a filter in the gas tank itself at the fuel pump intake. Have you checked the cam and crank position sensor and their wiring? How did that problem even arise? Even though the idle RPM is fluctuating a little bit it seems like the engine is either running "okay" or cutting out, nothing in between, isn't it? That would make a wiring / sensor problem more likely. |
Joep
Switch the NGK for Bosch spark plugs. I know many in the UK disagree with me, but in the Netherlands we only have issues with NGK in stock RFS engines.________________________________________ My car park:'96 Sigma Blue XSi6 '98 Diablo Red GTi6 '99 Onyx Black S16 All RFS powered! Plus various other Peugeots |
Bakov
A simple 4-pin 25A relay was installed today, now the injectors and coils are powered with +12V separately via this relay and earth from ECU. The relay is controlled only from ignition key, in this moment i think thath my engine runnig well, The original double function relay is still there to power other parts from the system |
