Author Subject: Door Check Strap
I'm dismantlting my damaged driver's door for the lock barrel, etc and want to remove the check strap but can't get it through the hole. I'm cutting up the door to get the lock barrel out so can do the same for the check strap, but how can I fit to a good door?
Posted 28th Jul 2019 at 09:04
pug_306
Why are you cutting up the door ? The barrel is just held in place by a metal clip. The check strap is 4 x 10mm and knock out the roll pin. The lock and check strap are removed from inside the door
1992 205 GTi6
205 Turbo 340bhp
Posted 28th Jul 2019 at 09:38
My door was badly crushed by the artic so no space to get the contents out!
I'll cut out the check strap then knock out the roll bin on a bench - Can they be re-used?
Posted 28th Jul 2019 at 09:53
