I'm looking for some replacements and think the OEM is TRW, but have seen two types with differing faces.I've found the folowing inlet valves:
R6060/S - Inlet Valve FRECCIA
V94167 - Inlet Valve AE
1973IN - Inlet valve OSVAT
537141 - Inlet Valve TRW Engine Component
Some are 34mm and others 34.1mm
and exhaust valves:
R6061/BMARCR - Outlet valve FRECCIA
V94168 - Outlet valve AE
1974EX - Exhaust valve OSVAT
537148 - Outlet valve TRW Engine Component
All these are 30.7mm
Any advice on the correct ones to buy?
S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired
