Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader
| Author | Subject: Checking alarm siren with multimeter. |
As per title I'm having a clear out and found 4 sirens. Can these be checked with a multimeter without power from car? If so what pins and what am I looking for voltage wise that might imply they have a chance of still working before they all go the tip. Would any residual battery power give a false result? Unlikely as they've been they're for nearly 9 years or more.________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
I'm looking for one but all the bateries are now dead but you can dig out the old ones and replace.Can I get these from you and try to repair? ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
they have 3 wires if i remember0V 12v coms/trigger wire. the batteries in them are resin potted trying to change them will destroy the board if the water has not already i replace mine with one from a later 206 as they use the same part with matching part numbers |
mellowr1
Senior User Location: Maidstone Registered: 12 Jun 2012 Posts: 995 Status: Offline |
rudolf wrote: I'm looking for one Aren't we all |
mellowr1 wrote: rudolf wrote: I'm looking for one Aren't we all He got four.... ________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
cully
the alarm sounder unit part no 6680 97 is listed on service box as fitting ....106 206 306 406 605 607 806 partner Berlingo Saxo Synergie xantia xm xsara zs |
pug_306
Seasoned Pro Location: Great Hockham Registered: 28 May 2013 Posts: 1,597 Status: Offline |
What would you say a brand new boxed one is worth?________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
mellowr1
last time i looked a new one was about £180 |
mellowr1
mellowr1 wrote: last time i looked a new one was about £180 Make that £197 |
