Author Subject: Clarion CD/Radio
I'm picking up a lovely Astor but has an aftermarket Radio.
Anyone got a spare original phase 3 CD/Radio and CD changer?
Posted 8th Jun 2019 at 09:21
I've now got the head unit and cable so just need the changer.
Also, what should the cage look like and has anyone got one?
Posted 30th Jun 2019 at 22:09
Cage for the changer? Older ones had a metal L brackets that bolted/screwed into the changer IIRC phase 3 has a Velcro strap screwed into wheel arch with two plastic screwed in points as per image below.
Posted 1st Jul 2019 at 01:45
Hadn't thought of how to mount the changer.
I'm looking for a photo of the head unit cage.
Posted 1st Jul 2019 at 07:46
I sent you the cages on the 2 stereos. They slide into the aperture and the bolt/bung at the back of radio holds it in place at the rear as per this FAQ.
http://www.306gti6.com/forum/showthread.php?id=72114
Posted 1st Jul 2019 at 17:04
I wanted to know which one was the correct one as they are different.
From the FAQ, it looks like the blue one is correct.
Posted 1st Jul 2019 at 18:18
Oh right, the blue one is the one that came from my car from the factory the other from a breaker which was probably the T or V reg from memory.
Posted 1st Jul 2019 at 19:37
malo225
Still looking for a changer I have one and a cable
Send me a pic of the connection on the back of the head unit
Posted 23rd Aug 2019 at 09:53
-er-
I have a question, too? Do you have any suggestion to insert USB or AUX instead of CD changer into original Radio ?
My Channel EREL
Peugeot 306 GTi-6 N5 / PH2 / Diablo Red / Mustang Red Cloth (Sold Sad )
Peugeot 306 GTi-6 N5 / PH3 / Diablo Red / Alcantara Suede
Peugeot 306 GTi-6 N5 / PH2 / Bianca (Sold Sad )
Posted 23rd Aug 2019 at 11:45
S8-Tom
I soldered an RCA cable to the cassette section of the circuit board. It worked but very quiet volume and noisy.
A better option would be to solder the RCA to the CD changer cable; I've got a wiring diagram for the Clarion PU-1570 but I haven't worked it out/lost interest.
Posted 23rd Aug 2019 at 15:12
miki4
I did that once to an old Megane's cassette radio. You have to somehow deactivate the tape part for the noise to stop. At least that worked in the radio I was working on.
In my old Ph3 306 1.6 I modded the original CD radio in this way. Inject the audio signal from an RCA or 3.5 mm cable into the audio path that goes from the CD reader unit to the audio processor on the radio mainboard, burn an audio disc with 80 mins of silence, put it in the radio and enjoy. Don't forget to put some resistors in-line (L/R channel) to protect the IC depending on where you solder the wires to. I used something between 500 Ohm and 1,5 kOhm. Maybe I find some pics.
EDIT: Unfortunately no pics from inside, only from outside from when I put an ad up to sell it. I ran a cable with a female 3.5 mm connector out of the rear of the unit so I could connect it to a jack i mounted inside the tray above the ashtray. A second 3.5 mm jack I mounted to the faceplate so I could have music from my MP3 in the tray at the same time as e.g. notifications from satnav, mobile etc. mounted on the vents. A jack from an old Nokia fit perfectly.
https://imgur.com/a/qGHX0Du
Posted 31st Aug 2019 at 18:19
