Author Subject: Engine
prparke
GTI 6 engine not starting, its turning over that's it. replaced fuel pump relay yesterday and no joy.
Posted 21st Mar 2019 at 08:18
pug_306
Are you getting spark and fuel ?
1992 205 GTi6
205 Turbo 340bhp
Posted 21st Mar 2019 at 08:26
Joep
Is it the original engine? Found out recently that the ECU has to match the keys when it is a phase 2/3.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 21st Mar 2019 at 09:01
prparke
quote:
[quote="Joep"]Is it the original engine? Found out recently that the ECU has to match the keys when it is a phase 2/3.
Engine, ecu, keys etc is from same car
Posted 21st Mar 2019 at 14:19
pug_306
But is it the original engine or have you swapped it from another car? If so did you swap the transponder also ? If so check if you have spark and fuel
1992 205 GTi6
205 Turbo 340bhp
Posted 21st Mar 2019 at 14:22
prparke
quote:
[quote="pug_306"]But is it the original engine or have you swapped it from another car? If so did you swap the transponder also ? If so check if you have spark and fuel
3 doorGTI 6 car everything from it was swapped over
Posted 21st Mar 2019 at 15:41
pug_306
Including the transponder control unit in the dash ?
If so do you have spark and fuel ?
1992 205 GTi6
205 Turbo 340bhp
Posted 21st Mar 2019 at 15:46
prparke
quote:
[quote="pug_306"]Including the transponder control unit in the dash ?
Transponder, dash, speedometer etc.
Posted 21st Mar 2019 at 17:41
miki4
Does the engine management light turn on with ignition? If so, you need to verify if you get spark and fuel as pug_306 already said.
Posted 22nd Mar 2019 at 00:33
fletch
Track Head
Does the fuel pump prime?
Fuel? Spark?
Dodgy crank sensor could be at fault
Posted 22nd Mar 2019 at 14:01
Cjwatson27
Red cut out switch
Posted 22nd Mar 2019 at 14:18
