Author Subject: Rev counter not working
Joep
Hello,
Two weeks ago, the rev counter stopped working. I started the car, revs went up... and then down. I checkt the plugs at the back of the clocks and these are fine.
Anyone any suggestion what can cause this issue?
It is a phase 1 GTi6 (well, to be precise a phase 1 XSi with RFS fitted).
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 18th Feb 2019 at 08:18
there are a few things i've personally come across in the past that caused these same symptoms,..
1. check that your battery terminal connections are clean and tight!
2. there's a silver looking fuse under your steering column i believe this can pic up static and interfere with the signal
3. check that all your earthing points in the car are clean and well grounded!
4. the wiring loom from the engine runs up the right hand side of your cassis leg (looking from front)
check that there are no breaks to the wiring if their are splice in another piece
on my car it was a white wire that relayed the speedo's signal
5. check the main engine wiring loom plug for corroded pins
(if this is the case sand and clean up!, you may need new O'Ring Seals)
hope some of these ideas help!
Posted 18th Feb 2019 at 11:18
Joep
Thanks! This information is very helpfull! I will check all of these over the coming days and report back what was causing the issue.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 18th Feb 2019 at 11:38
Nose
quote:
[quote="gnrlee"]there are a few things i've personally come across in the past that caused these same symptoms,..
Had the same on the Rallye, my issue was number 4.
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 18th Feb 2019 at 11:53
Joep
Feedback on this issue:
Last Sunday I started the engine and the rev counter was working! No idea what has changed since I parked the car last week...
Also, the oil pressure gauge did show something... most likely oil temperature as I do not have an oil pressure sensor installed. IIRC, there was a oil temperature sensor installed during the engine swap.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 5th Mar 2019 at 10:19
