Author Subject: Clutch pedal on the floor
asim_pug306
Went to move the car last night, put the clutch down and it just got stuck on the floor. It'll come up by hand but even the slightest touch on the pedal and it springs straight back down. A quick glance and the cable seems to be in tact
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 4th Jul 2018 at 10:07
marksorrento205
Clutch cable snapped or become uncooked at the pedal? Does the clutch arm move on the gearbox when the pedal is moved?
Posted 4th Jul 2018 at 16:54
Yep, sounds like it's snapped. As Mark says, check the arm moves on the gearbox when using the pedal. I reckon it won't.
Clutch cable isn't too bad a job, can be a bit awkward if you've got air-con.
Posted 4th Jul 2018 at 20:50
asim_pug306
New clutch cable fitted but still no joy
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 10th Jul 2018 at 08:47
Is the clutch arm pin still in place?
Posted 10th Jul 2018 at 12:06
fatlapit
Ledal mechanism working??
Posted 10th Jul 2018 at 20:33
asim_pug306
Ignore my above post, I was wrongly informed at the time!
A new clutch cable did actually sort it. However last night I took the car out for it's first proper drive since having it back. After around half an hour, it became really difficult to get the thing into gear and you can feel it struggling slightly at junctions with the clutch down. It actually feels like there's less travel in the pedal too.
I've just gone back to the garage this morning and they've said that the cable should self adjust so that can't be at fault? They think it's the pressure plate but it's a bit strange that my car never did this before the cable snapping
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 19th Jul 2018 at 10:38
Give it a couple of days they are self adjusting though!
Posted 19th Jul 2018 at 12:44
barrym
quote:
[quote="asim_pug306"]Ignore my above post, I was wrongly informed at the time!
I had this exact same issue with a new, but faulty, cable. It needs replacing again I reckon
Black Rallye occassional toy
Posted 19th Jul 2018 at 18:51
asim_pug306
quote:
[quote="barrym"]I had this exact same issue with a new, but faulty, cable. It needs replacing again I reckon
Was yours a genuine dealer part or pattern?
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 20th Jul 2018 at 14:34
miki4
My ATE clutch cable which seems to be the only one available for a LHD GTI6 with a well-known brand on it also has way too much play on the top of the clutch pedal travel. It's self-adjusting and adjusts itself always to this s**t state. I will be replacing it to a OEM one.
Posted 20th Jul 2018 at 15:39
barrym
Was a pattern part, but even OEM parts can be faulty. Mine was actually fine almost all the time. It only played up on very hot days after being stuck in traffic. The amount of pedal travel would go down. A couple of quick pushes of the clutch pedal would 'reset'it for a bit but it would gradually get worse. Park the car up and let it cool down and it would be fine again for a while. took it back to the garage that fitted it and they just replaced it under warranty, been fine ever since
Posted 20th Jul 2018 at 19:43
asim_pug306
Still not solved this. So we went and replaced the clutch cable again for an OEM one from Peugeot this time. Again had exactly the same problem, stiff gear change once up to temperature.
My friend reckons this little bush doesn't look in too good shape and could be causing the problem.
IMG-20180807-WA0005 by Asim Malik, on Flickr
The cable did seem to have some play in it from on top of the gearbox after it was fitted. Question is will I be able to get one of them little things
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 7th Aug 2018 at 19:57
barrym
The bush is available from Peugeot. Part number 2175 21. £2.59 +VAT
Posted 8th Aug 2018 at 18:38
malo225
I would replace the bottom one too
Posted 9th Aug 2018 at 21:30
miki4
Yes, replace both ones. And there is a newer revised design of them available. Get the newer ones! AFAIK they are less prone to wear out from ingress of clutch dust. Unfortunately I cannot access ServiceBox where I am right now but someone should be able to find out the part numbers.
Posted 10th Aug 2018 at 12:49
