Author Subject: Brake caliper repair kits
Scottlarr
Hi all, just wondering if these are indeed the right bits I'm after. Have a 1998 GTi6 with standard calipers.
https://m.ebay.co.uk/itm/FRONT-Brake-Caliper-Repair-Kit-Pistons-for-PEUGEOT-306-1997-2002-BRKP203/311934581609?fits=Car+Make%3APeugeot%7CModel%3A306&hash=item48a0bffb69:g:xeIAAOSwxxVZibG4
https://m.ebay.co.uk/itm/Peugeot-306-1997-2001-REAR-Brake-Caliper-Repair-Kit-Pistons-BRKP67/282711810643?fits=Car+Make%3APeugeot%7CModel%3A306&epid=14004255045&hash=item41d2efe253:g:vBMAAOSwd4tT7IvB
Already ordered new pins, anything else you guys would suggest is welcome!
Many thanks!
Scott L.
Posted 22nd Apr 2018 at 11:38
miki4
Definitely compare the new and old parts before rebuilding and decide if you could not reuse the original pistons and pins. Often the original part's surface finish is smoother and if it isn't completely rusted you can clean it with WD40 and remove potentially existent surface rust with some fine wet sand paper.
Recently I bought a pair of rebuilt rear calipers by ABS (All Brake Systems) and the sliders were complete crap. You had to overcome a rather high breakaway torque for it to start moving and you could feel the pins grinding in its guide. I replaced them with the original pins, lubed them up well and everything's nice and smooth now. The rubber seals also fit better on the original pins.
Posted 22nd Apr 2018 at 15:15
Nose
Hi Scott, there's a caliper company in Worcester called Big Redd, have a look on there mate, they'll do the kits.
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 22nd Apr 2018 at 19:48
Scottlarr
Ahh alright I'll bare that in mind, cheers guys! I'll be sure to have a good check over everything to make sure it all performs as it should!
Scott L.
Posted 22nd Apr 2018 at 20:41
Rich E Forum Admin
The kit linked to for the rears is correct, but the one for the fronts is wrong. The GTi-6 has 57mm pistons in the front calipers.
Posted 22nd Apr 2018 at 20:44
