Author Subject: piston pin to crown height
barrym
Hi all,
with my current engine now at 201k and using a little oil I am looking to build a replacement. There are direct fit Wossner pistons available I know, but 86mm is a very common piston diameter and it doesn't hurt to dig a little deeper.
What I need to know before digging though is the pin to crown height of a standard RFS piston, and I just realised the pin diameter too.
And before I try and probably fail to re-invent the wheel, I seem to remember there might be a direct fit piston mentioned on here before. Was it a Vauxhall c20?
Your help will, as always be appreciated
Barry
Black Rallye occassional toy
Posted 20th Apr 2018 at 19:45
barrym
I should have said too, I am potentially using Catcam 110's or PH4's hence not being able to use standard pistons
Posted 20th Apr 2018 at 19:58
cully
C20LET rings for the original pistons Wink
not sure on the pistons im sure our welsh friend will be along soon Wink
Posted 20th Apr 2018 at 23:47
