Author Subject: Oil cooler fitting help
foot
Im about to fit a Mocal 16 row cooler but not quite sure what to do with the original heat exchanger coolant lines.
I'm talking about the coolant pipe running from the standard heat exchanger to the rad and the one running up to the top rad hose.
I was thinking i would just blank the one off that goes too the top hose and remove the one going to the rad as I'm planning to fit a new Rad that doesn't have that outlet.
any help appreciated
Tom
Posted 14th Mar 2018 at 09:34
cully
I have left mine on as it it helps with the warm up cycle and when hot it transfers heat from oil to water so double bonus road driving or track
Posted 14th Mar 2018 at 10:17
3rd time lucky
Mine is also left on. Beware of a few mocal 16 rows with leaking cores. Mine was one of them.
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 14th Mar 2018 at 11:29
foot
how did you manage to keep the heat exchanger plus the oil cooler sandwich plate?
i can't imagine you would have enough room??
Posted 14th Mar 2018 at 11:30
I'm pretty sure there was space on mine with the std heat exchanger, mocal sandwich plate and std length oil filter.
Posted 14th Mar 2018 at 12:12
3rd time lucky
Nissens rad helps
BLACK RALLYE - Sold
Posted 14th Mar 2018 at 12:38
foot
yeah I'm installing an ally rad but it doesn't have an outlet for the oil heat exchanger on it as i was intending on removing it
Posted 14th Mar 2018 at 13:38
I would deffo remove the original heat exchanger. It makes fitting the cooler a lot harder but I found it doesn't didn't really work that well otherwise.
I've just joined the original water pipe to another running down to the radiator.
Posted 14th Mar 2018 at 18:43
cully
quote:
[quote="foot"]how did you manage to keep the heat exchanger plus the oil cooler sandwich plate?
loads of room.....Thumbs up
Posted 14th Mar 2018 at 19:36
blandy
I have mine removed completely just use a male/male adaptor in the block to bolt the take off plate to
Posted 14th Mar 2018 at 19:50
foot
Yeah I still don’t understand how having both is going to work the heat exchanger will just keep the oil cooler and stop the thermostatic sandwich plate from operating correctly so therefore you won’t have flow through the oil cooler?? Or am I not understanding this correctly??
Posted 14th Mar 2018 at 19:52
cully
im using a thermostatic sandwich plate it only diverts oil to the cooler when oil is above 90c ish
remember the existing cooler can also transfers heat from water to oil too cooling the block
Posted 14th Mar 2018 at 20:04
quote:
[quote="cully"]im using a thermostatic sandwich plate it only diverts oil to the cooler when oil is above 90c ish
Sadly my thermostatic Mocal sandwich plate went faulty and started sticking and my heat exchanger was leaking so removed both and use a full open circuit now but I wouldn’t advise this for Road driving ...but excellent on track ...I just put cardboard over my 19row if it’s a cold day on track Thumbs up
I had a new 19row Mocal leak also and don’t buy Mocal now I just buy Setrab Thumbs up
Posted 14th Mar 2018 at 20:43
foot
Ah man you have me worried now I hope mine doesn’t leak 😬
Posted 14th Mar 2018 at 21:25
cully
my Thermostatic plate was stuck too but its easily fixed with a file Wink
also running a Setrab oil rad
http://www.306gti6.com/forum/showthread.php?id=164228
Posted 15th Mar 2018 at 06:48
its common practice on rally cars to retain both as the coolant always gets to temp faster than oil, which with a heat exchanger can bring the oil up to operating temp a lot quicker, which is a good idea for engine efficiency.
when the oil gets hot it works the other way and dumps heat into the rad, obviously when used very hard there isnt the capacity there to get rid of the excess heat so an additional air to oil exchanger is used.
Posted 15th Mar 2018 at 12:57
quote:
[quote="cully"]my Thermostatic plate was stuck too but its easily fixed with a file Wink
Sadly Paul No pics now to help other m8 Thumbs down
Posted 15th Mar 2018 at 18:18
cully
quote:
[quote="Day666"]
i see pics maybe people need to investigate plugins for there browsers "Photobucket Hotlink Fix" works for chrome Wink
Posted 15th Mar 2018 at 18:35
foot
Yeah sadly no photos on Safari ☹️
Posted 15th Mar 2018 at 20:12
fatlapit
Mocals a bit w**k try motamec
Posted 15th Mar 2018 at 21:22
quote:
[quote="welshpug!"]its common practice on rally cars to retain both as the coolant always gets to temp faster than oil, which with a heat exchanger can bring the oil up to operating temp a lot quicker, which is a good idea for engine efficiency.
Really didn't work on my car with the charger, hence why I've binned it off
Posted 16th Mar 2018 at 07:55
3rd time lucky
quote:
[quote="adam b"]
Something must have been wrong then...
BLACK RALLYE - Sold
Posted 16th Mar 2018 at 08:46
