Author Subject: Brake switch help
Mr Jones
Hi,
my brake lights were permanently coming on and after checking the brake light switch, above the brake pedal. it had popped back through the hole. Are there any tips on how to reach in and place it back in? it seems almost impossible to reach round the back?
thanks
Posted 17th Jan 2018 at 15:47
barrym
Hi, I did mine through the drivers side air vent, the one by the window. And I still have the scars to prove it
Black Rallye occassional toy
Posted 17th Jan 2018 at 16:15
Mr Jones
Cool thanks, didnt think about approaching it from above.....seems quite a way off but if you're still wearing the scars and it worked then i'll probably be tattooed up the same way over the weekendThumbs up
Posted 17th Jan 2018 at 17:26
cully
what a feckin job dont enve you
last one i did the plastic grommet was worn so the switch kept poping out
ended up cutting a hole in the steel behind the clocks to get a straight push
oh and i cut my arms to shreads!
Posted 17th Jan 2018 at 18:05
barrym
Now I think about it I removed the plastic collet type thing as I couldn't get enough leverage on the switch to push it through. I used a thin cable tie pedal side to secure it and stop the switch going back up
Posted 17th Jan 2018 at 20:04
barrym
Or just follow the Haynes instructions.
1. Remove dashboard
2. Replace switch
3. Refit dashboard
Posted 17th Jan 2018 at 20:05
Removing the steering column improves access somewhat Thumbs up
Posted 18th Jan 2018 at 16:19
Mr Jones
Thanks very much for your advice gents..... sorted, going through the vent was the best option for meThumbs up
Posted 18th Jan 2018 at 16:27
Cvnt of a job and rips your arms to bits
Posted 19th Jan 2018 at 20:58
